02-26-2022, 08:47 PM | #1 |
Rep 112
Never really had a data log checked by anyone else, just something I did on my own in the past to make sure everything looks fine, but really I'm an amateur. If you guys could please take a look at my logs and see if they look good. I was also thinking about running the Stage 2H E30 map on my stock turbo because some people have been doing that and it seems like it's fine. Also saw somewhere that bootmod3 recommended it to some people too. Anyways what do you guys think about my situation and does anything stand out that I should check out?
Mods: BM3 Stage 2 E30 PWG VRSF downpipe VRSF charge pipe CSF FMIC AWE axleback with stock midpipe NGK plugs factory gap (changed plugs a few months back that were gapped) AFE momentum intake xHP stage 3 transmission tune Conditions for logs were all dry, sport+, also its like 20-30°F here in Chicago Log 1 2nd-3rd : https://www.bootmod3.net/log?id=6216...0b435cc4d11e82 Log 2 3rd-4th (kinda long) : https://www.bootmod3.net/log?id=6219...0b4333683e6388 Log 3 4th only : https://www.bootmod3.net/log?id=6216...0b435cc4d11e81 Again any input at all would be greatly appreciated |
02-27-2022, 06:36 PM | #3 |
Rep 112
Yeah I'm PWG. I noticed that the car wasn't pulling as hard after I flashed v 8.1 from 7.2. But that probably doesn't change that I might have a leak. What are some things I should check? Maybe just order a new boost solenoid to see if that fixes anything?
02-28-2022, 11:35 AM | #4 |
Rep 7,622
No don't throw parts at it... you need a pressure/smoke test of the entire charge pipe system from turbo to engine to see if there are any leaks on TIC/IC/CP connections etc. You can also try relogging old tune version to make sure its not software
