03-02-2022, 02:35 AM | #1 |
Rep 164
OCPP - BMW App
Does anyone know if the BMW App is OCPP compliant? Octopus Energy in the UK offers an Intelligent tariff that can charge EVs to a pre-set SOC in the early hours of the morning. The tariff works with OCPP-compliant EVSEs or cars via their Apps.
It has been reported recently that the tariff now works with the E-Golf and IPace but I have seen nothing yet regarding BMWs. If the timings are being set in the car then, as I understand it, Octopus needs log in information for the App. |
03-02-2022, 03:28 AM | #2 |
Rep 366
As far as I've been able to work out, the BMW app is not OCPP compliant as of now. However there is a HomeAssistant plugin for BMW that has a 'charge now' remote capability.
https://www.home-assistant.io/integr...onnected_drive https://bimmer-connected.readthedocs...RemoteServices I use this to get charge status information from my iX3 but have not had the time to try and bridge this with OCPP to automate anything yet, though in theory it would be possible. |
DaveCV37.00 |
03-02-2022, 05:10 AM | #3 | |
Rep 840
What is clear is you need either a Tesla or Wallbox charger - hence why I bought the latter. My understanding is that they will connect to the charger to start the charge - the car just needs to be set to charge immediately. You also need an iPhone - Android implementation is on the way. |
Rathian153.50 |
03-02-2022, 07:43 AM | #4 | |
Rep 164
iX3 rijder47.00 |
03-10-2022, 11:49 PM | #5 | |
Rep 126
I do have reduced tariff on scheduled hours, so I programmed my charging to take place during “low tariff” and when my solar panels supply enough. For the “actual low tariff” you will need a contact in your distribution panel which is operated by your energy supplier to indicate high/low tariff times. In Holland we do not have this (yet) but I understood UK has a system like that. MyEnergi (Zappi manufacturer) has proven to be very helpful in supplying info. |
03-11-2022, 10:13 AM | #6 | |
Rep 164
https://octopus.energy/intelligent-octopus/ It would be great if MyEnergi could enable this via the App. Getting BMW on side might be a bit trickier as they reluctant to admit that there is a Charge Delayed issue with Eco+. |
