BMW 2 Series Technical Topics (G42) Wheels / Tires
      03-03-2022, 10:31 AM   #1
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
Michelin Pilot 4s vs 4s BMW star
Some folks were wondering about the Michelin Pilot Sport 4s BMW star version of tire and the difference with the regular 4s. Note: Michelin makes a BMW spec tire that is referenced as the BMW star and has a star embossed on the side of the tire.
There is a web site tyrereviews.com that has an article specifically on this. Look under "features" on the right side and the title Michelin 4s and BMW Star or something like that. There apparently is considerable difference, the author spent time with a Michelin rep and the details are included...an example:
What are the exact differences between the * marked PS4S and the regular aftermarket tyre?
This is the bit that took nearly an hour to explain, so I'll be paraphrasing a lot here, but a lot has changed!
The compound is the biggest difference, as with the OE tyre you can design the compound around the specification from BMW, and the changes are far greater than even I'd imagined with my small amount of insider knowledge.
The aftermarket tyre has a 2 compound design, with what Michelin calls black carbon + on the outer section of the tyre for cornering grip, and a high silica compound on the rest of the tread which is great for many things like wet grip, low rolling resistance and good mileage.
The BMW specification front tyre not 2, but FOUR compounds! Firstly, the black carbon compound they use is black carbon+++, with two extra plusses. This I've been told is more like the cup 2 compound than the 4S.
there is more, thats just a part. read up if interested.
Also Pirelli also makes a BMW star specific Pilot Zero pz4 but i don't know the specific differences on that tire. That tire is very common factory provided tire on the M240x.
e36uulm94.00
jbazz258.00
XC3LLR82086.50
      03-04-2022, 05:43 PM   #2
XC3LLR8
Drives: Super73
Haven't checked the link yet, but did Michelin confirm the BMW spec'd 245/35 is a 6.8" tread width compared to 8.6" for the non-BMW spec?
      03-04-2022, 07:44 PM   #3
danallxt
danallxt's Avatar
yes, but i don't think they actually went out and measured like they did with the 275s....so I'm still questioning the 6.8 number.
XC3LLR82086.50
      03-18-2024, 05:47 PM   #4
RyanM3Z
Drives: 2011 ZCP M3
Rears not available in BMW Spec Tire
Michelin makes the OEM spec Pilot 4S for the fronts (245/35ZR19) but there is no OEM spec/star Pilot 4S for the rear (265/35ZR19)
model Car: 2019 M2 Competition
What is the resolve here to get the same tire on the rears?
      03-18-2024, 11:24 PM   #5
AlexC2er
AlexC2er's Avatar
Drives: G42 M240i RWD
I don’t know fitment of f87 M2c but you could go 275/35r19 that does have a star spec. Or simply go with non star ones which is fine
