Engine Oil service due
03-03-2022, 03:03 PM | #1 |
Rep 30
Hey guys,
2011 / 328xi / 61K. Just purchased the vehicle 2 months ago and the dealer (bought from Shift) said the oil change was done on 11/9 and the car hasn't been driven more than 200 miles since I took possession in Jan. Anyway, today the 'Engine Oil Service Due' notice came up on the iDrive screen. Do you guys recommend I get an oil change and get a fresh cycle under my belt? |
03-03-2022, 03:22 PM | #2 | |
Rep 809
Second they told you that because whenever the oil was changed last time maybe they didn't rest the mileage timer so now you need to just be sure change the oil and rest the oil change interval just for a piece of mind (It's worth it!) |
03-03-2022, 04:00 PM | #3 | |
Rep 558
3/4 my BMW's were new, only last one was used. I figured it was cheap insurance/peace of mind to change engine/diff/ps/transmission fluids, air and fuel (diesel specific) filters. Diff & PS fluid: at 135K miles was justified, you can hold on to 100K+. Certainly change transfer case fluid. |
03-03-2022, 06:32 PM | #4 |
Rep 2,529
Drives: 2011 328i Wagon
Two thoughts - How do you know a car salesman is lying? His lips are moving... And there is no such thing as fluids that are "too fresh". Unless you were provided documentation that the oil was changed, assume it was not.
Were it my car, I would change the oil, reset the oil life monitor, and be on my merry way. Actually, if it was my car I would change every single fluid in the car as soon as I bought it - which I did when I bought my 46K mile 128i convertible summer of '20. And my Volvo last year. And every other used car I have ever bought. Especially for Xis and autotragics - change those particular fluids early and (relatively) often.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
03-03-2022, 08:36 PM | #5 |
Rep 18,801
Don't know who Shifts is. If not a BMW dealer, then they don't understand the E90 CBS system and probably used non-spec oil and the wrong oil filter. Put BMW LL01 oil in it and a MANN HU-816x filter in it.
03-03-2022, 08:44 PM | #6 |
Rep 2,529
SHIFT is another online car dealer like Carvana. I am sure they don't know their ass from a hole in the ground.
Efthreeoh17427.50 |
03-04-2022, 05:52 AM | #7 |
Rep 18,801
That makes it even worse. When I bought my Z4 from CarJax, they used an ill-fitting oil filter. Those jokers possibly know a little bit about cars... maybe. Some on-line car flipping company? Lol, ood luck with that.
03-04-2022, 11:25 AM | #8 |
Rep 360
trehman How long do you plan on keeping this vehicle? As has been noted above, it's good to swap out every fluid in a used a car when you buy it so you have a baseline. If you do it yourself, its a few hundred bucks and an afternoon (or a day, if you're new to it) of your time.
2007 X3
2022 M3 Base |
Efthreeoh17427.50 |
