E90/91 LCI rubber door trim alternatives.
03-11-2022, 12:49 PM | #1 |
Rep 247
Guys. Looking to change the rubber door seals around the doors themselves. Not the apertures. Is there any cheaper alternatives to buying them from the dealer, I don't mean secondhand ones here but new seals aftermarket?
03-11-2022, 01:43 PM | #2 |
Rep 217
Drives: 2007 BMW 335i E90
It would help to find the part number of what you're after. If what you're describing is what I think it is, probably not.
You can find the part number using RealOEM.com and can search on FCPEuro.com which usually carries OEM plus aftermarket alternatives for a lot of items. |
03-11-2022, 02:25 PM | #3 | |
Rep 247
03-11-2022, 04:02 PM | #4 |
Rep 3,200
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
03-11-2022, 05:14 PM | #5 |
Rep 217
Yep I was about to recommend eBay. Here in the US it appears to be anywhere from $20-60 cheaper but OEM and in new condition.
03-11-2022, 06:24 PM | #6 | ||
Rep 247
