03-12-2022, 10:50 PM | #1 |
Rep 66
How do my Stage 2 ACN data logs look?
Car: 2014 335i xDrive 8AT EWG
Mods: CL DPs, CP, BM3 Stage 2 ACN 91 20,000kms on sparkplugs, NGK OE pugs Both runs were done in 3rd gear, not sure if I should redo in 4th? Going to be upgrading my intercooler so wanted to know how the boost targets and actuals look. Also, noticed a knock on one of the logs, guessing it's just from poor fueling, don't really notice any rough running. Run 1: https://www.bootmod3.net/log?id=622d...0b43199611332f Run 2: https://www.bootmod3.net/log?id=622d...729b7192e8b2a6 |
03-13-2022, 05:48 AM | #2 |
1297
Rep 3,536
Your boost is great.
Your fuel is absolutely trash. You NEED an IC for stage 2 bad (even stage 1 really). Go back to stage 1 until you have the correct supporting mods.
Kooner2320.50 |
03-13-2022, 01:28 PM | #3 |
Rep 66
Thanks for your input! The intercooler is here and going to be putting it in. Just wanted to do some quick logs before installing to help trouble shoot if anything happened post intercooler install.
Is it normal to see pre throttle boost being 2PSI higher than the target boost? |
03-13-2022, 07:43 PM | #4 | |
1297
Rep 3,536
03-14-2022, 01:37 PM | #6 |
Rep 1,425
Where do you get gas from?
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
03-14-2022, 04:38 PM | #7 |
1297
Rep 3,536
Irrelevant unless you live in the same area as him fyi fuel is not always consistent even if the station brand is the same and nearly right next to each other.
Kooner2320.50 |
03-14-2022, 11:13 PM | #8 |
Rep 66
