BMW 2 Series Technical Topics (G42) Wheels / Tires
      03-17-2022, 01:53 PM   #1
cb123
Drives: Bmw 2022 M240i
Car Jack and Spare Tire Recommendation
Can anyone recommend a good car jack for the m240i ? Also, Has anyone bought a spare tire? if yes, where from? Thanks Tire size 225/40/19
      03-17-2022, 04:39 PM   #2
jpcoop
Drives: 2022 M240i xDrive
I'd highly recommend just buying the tire inflater set that comes with the car (for those that ordered without run flats). It'll cover you about 90% of the time, and you'll still be able to use your trunk.
By the time you get a jack and a spare in your trunk it'll be full...
      03-17-2022, 04:41 PM   #3
jpcoop
BMW Mobility Kit: Part # 71-10-2-333-674 for about $150
Or get a can of fix-a-flat for twenty bucks if you want to save a buck
There's a reason these cars don't ever come with a spare tire. The mobility kit is the "OEM" solution.
      03-22-2022, 08:19 PM   #4
Ruebarb
Ruebarb's Avatar
417
Drives: BMW G42 M240i
Modern Spare, not cheap$$
https://modernspare.com/
I bought the jack kit, not the spare, spare would leave no room in trunk. Between the BMW mobility kit and the tire repair kit I bought, I should get by without a spare. The jack may be needed to repair the tire, as you may need to remove it to patch.
jbazz259.50
      03-23-2022, 10:57 AM   #5
cb123
Thanks for your reply. I'm waiting to hear back from them. Seems like they only have size 18? Are there any other options from BMW? Do they offer a space savor for our car? Did anyone actually get another full size wheel and tire and throw it in the trunk?
      03-23-2022, 12:39 PM   #6
cb123
I was told that size 18 was ok but I would need a spacer for the brakes. Can anyone confirm this?
      03-24-2022, 08:09 AM   #7
cb123
Has Anyone actually tried to see if this spare fits with the spacer, for those who have one?
      04-03-2022, 05:30 PM   #8
AndyTurboI6
Drives: 2022 BMW M240i
I just received this and it fits with the spacer. I put it in the trunk. With the frequency of punctures in Northern NJ, I want to have a spare and am glad to have it.
jbazz259.50
      04-04-2022, 01:15 PM   #9
cb123
Thanks for your reply ! I was afraid it might not fit. How long did it take you to put it on with the spacer?
      04-04-2022, 03:17 PM   #10
AndyTurboI6
The procedure is to bolt the spacer to the hub with the OEM hardware. Then you bolt the donut to the spacer. I wasn’t trying for any speed records in my garage as I wanted to learn how to do it. I would say that bolting the spacer to the hub is a few minutes. But I’ll add that the complete kit is pretty good. I strapped the wheel in the trunk using the tie down hooks.
      04-05-2022, 08:41 AM   #11
cb123
Thanks for your reply ! I ordered the whole kit. Did you actually change you tires to non run Flats? I did and I noticed a big difference. Pilot sport 4S
      04-05-2022, 12:42 PM   #12
AndyTurboI6
Anytime! The car came without run flats so I do t know how that feels. However when I saw the mobility kit and remembered the damage I’ve had due to pot holes, I felt that a donut was in order. Get a pair of tie downs and use the hooks in the trunk to keep it from sliding around.
      04-05-2022, 01:58 PM   #13
cb123
Thanks for the tips. Enjoy your car !!
      04-05-2022, 02:18 PM   #14
AndyTurboI6
Same to you!
      04-06-2022, 12:38 PM   #15
edkato
edkato's Avatar
Drives: E92 328ix '11; G42 ‘22
I got a jack from modern spare (they’re very responsive btw) and have ordered a stock OEM wheel and tire from my dealer. Pricey, but I’ve been jammed up on road trips before and would rather make space than be without on a long trip.
F30 and E92 NOW G42
      04-06-2022, 06:22 PM   #16
AndyTurboI6
I totally agree with your assessment of Modern Spare and wanting to account for mishaps.
      10-13-2022, 10:26 PM   #17
sandrik93
Drives: '23 M240i RWD
Do you have the cooling and high performance tire package?
      10-13-2022, 11:32 PM   #18
Coconut
Coconut's Avatar
819
Drives: 2023 M240i xDrive
Doesn’t the mobility kit come with the $2400 HD Cooling and Tire Package?
      10-14-2022, 08:54 AM   #19
pw4
pw4's Avatar
97
Drives: G42 230i Msport
I'll be buying a full-sized spare wheel for my 230i when it arrives. The goo only works on basic punctures, not if there's a gash in the tyre or a damaged rim. And rural driving in Australia can mean a long distance between towns, and even further between towns likely to have a suitable replacement tyre.
On a recent club trip, one car hit a pothole badly enough to bend the wheel and destroy a tyre. Fortunately I had a spare wheel - we were out of cell phone range a long way from the next town. For our next road trip, at least 4 cars have spare wheels now!
      10-14-2022, 02:30 PM   #20
jpcoop
No, it comes with all of the non-runflat tire options. Of which there are several, mostly no-cost options.
Coconut818.50
