03-18-2022, 01:45 PM | #1 |
Rep 13
JB4 easy to remove/reinstall?
I want to install a VRSF DP and a BMS CAI, but am wondering just how much these will help without a tune. If I need warranty work done, is the JB4 fairly easy to remove/reinstall, and is a dealer likely to notice that the car was formerly piggybacked (either visually or diagnostically)?
Without the JB4, is it really worth the DP and CAI (aside from the sound)? Thanks for any advice for a B58 newbie! |
03-18-2022, 04:34 PM | #2 |
Rep 6
There’s a lot of in depth info regarding the detection ability of the dealers on this forum (mostly check 3 series b58) on detections. They can and will detect engine parameters out of spec and flag you as questionable. They won’t investigate it further unless an engine related claim comes up, but my understanding is if they plug in you’re flagged.
trstew115.50 Summeristooshort16.50 |
03-18-2022, 11:14 PM | #4 |
Rep 1,104
One more comment is that you would like to get a product that has more sensor taps than the JB4 has. The only thing going for this product which is a big deal is it has a built in failsafe versus other products that have more taps that reliably provide more power is great but there are no fail safes. I have tested many and worked with Burger and others direct for my prior X2M35i. However and recently, I believe Racechip finally has the best of all worlds for piggy back solutions with taps, features, and failsafes. As of like a month ago for B58 engines of our type but not up on site yet.
https://www.racechip.us/shop/bmw/3-s...-369lb-ft.html |
03-23-2022, 02:41 AM | #6 | |
Rep 202
03-23-2022, 04:41 PM | #8 |
Rep 94
Anything and everything can be found if the BMW team digs hard enough. We had a M235 gran coup flagged and voided for using race chip.
If you are thinking about a DP you will need a tune regardless, I think you should be more worried about the non-oem part in the vehicle voiding your warranty. If you have an issue, are you going to remove and reinstall the factory DP just to get service and then you are going to tell your technician you have no idea why youre having an issue and send them in the wrong direction on your vehicle, only for BMW to remotely scan your car and them find all of the sensors reading out of range, and boom, no more warranty. Granted the B58 has a lot of research and dev for performance parts and the car I mentioned was a 4cyl so not sure the gains possible compared to the easily 1000whp capabilities of the B58 but just remember even if your not flagged, they can still see everything your engine has sensed. I would consider a plug in but I would not replace anything like a cat unless youre ready to lose your warranty in the chance you have an issue. |
trstew115.50 |
03-23-2022, 05:06 PM | #9 |
Rep 13
https://www.bimmerpost.com/forums/sh...php?p=28721311
Will BMW flip out if I simply install a CAI?? Without a JB4, it would essentially be for sound, but now you've got me wondering... if I can't even replace the DP without worry, can I even replace the air filter? |
xcelir8bmw402.00 |
03-24-2022, 01:47 PM | #10 | |
Rep 144
03-25-2022, 11:04 PM | #11 | |
Rep 94
Granted as I stated, the b58 is a highly capable engine and can take more without batting an eye, just know the can of worms you are getting into with more than an exhaust, intake and a piggyback. |
03-26-2022, 09:37 PM | #12 | |
Rep 100
03-27-2022, 09:23 AM | #13 | |
Rep 281
Intake is a bit more risky since you are replacing the factory air box. I recall reading something on here about how some guy got totally screwed over because he had an aftermarket intake and experienced some sort of engine failure. DP without a tune should be relatively safe, although I would always recommend being upfront with your SA regarding mods and finding out where they stand before handing over the keys. My SA was super cool about bringing in my stage 2 FBO/catless F32, but he did mention that had I not told him ahead of time I would have been automatically been flagged by the new iSTA system.
2022 G42 M240i xDrive TM/TR
Past: 2019 F32 430i MG, 2015 F30 328i AW Last edited by idontsave; 03-27-2022 at 09:35 AM.. |
