03-25-2022, 07:44 AM | #1 |
Rep 957
Shark Fin Antenna Removal
Looking to get my roof wrapped in gloss black xpel PPF, but I'm not sure what to do about the shark fin as I've heard it's a PITA to wrap. I've read something about dropping the interior roof to get it off and then I've seen folks that used fishing wire to realize the 3M and pulled it off. Not sure what the process is, but anybody have experience with this?
My options are attempt to have the shop wrap it, take it off and get it painted gloss black, or just leave it in the Brooklyn Gray color. Any thoughts? I use XM so the carbon one from IND will not work.
[/SIGPIC]
03-25-2022, 07:50 AM | #2 | |
Rep 144
Fin comes off with a heat gun and a pry tool. I just got my roof wrapped. |
03-25-2022, 07:58 AM | #3 | ||
Rep 957
[/SIGPIC]
03-25-2022, 08:41 AM | #4 |
Rep 144
03-25-2022, 09:24 AM | #5 |
Rep 933
I would recommend not removing it, just have the wrap go around it.
FWIW, if you do remove/reinstall it and the car develops a water leak from there and you take it into the dealer you will probably be paying for the repair.... |
03-25-2022, 09:40 AM | #6 |
Rep 1,676
When I did that on my old 340 I just bought a cover from eBay. Less than $30 and just double sided tape over existing. Just choose a US seller not China so you aren't waiting months.
03-25-2022, 11:04 AM | #7 |
Rep 957
A lot of folks I read have removed over the years. Some say that 3M holds them on and some say a glue. If 3M, I'm sure that it could be replicated when out back on. I haven't seen water become an issue yet, but I also don't want to be the first.
[/SIGPIC]
03-25-2022, 02:00 PM | #9 | |
Rep 957
Can you share a picture of your roof?
[/SIGPIC]
08-06-2022, 01:20 AM | #12 |
Rep 129
my wrap guy did plastic dip for my matte wrap It's close but very tough to wrap otherwise. On my other cars with clear wrap he skipped it.
2023 CSL FBG/powered buckets - 2022 X5m BSM/Sakhir - 2020 M2c HS/Blue -
2007 M5 BSM/Black - 2004 M3 LSB/LSB - 2001 M5 Carbon Black/Imola |
08-06-2022, 02:37 PM | #13 |
Rep 6
08-06-2022, 10:06 PM | #14 | ||
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3546
Rep 4,228
DO NOT USE 3 M tape. You need to use a long box cutter blade and be very careful. Having tape double or even tripled around the entire perimeter of the fin. Having a 2nd person gently but firmly pulling against the fin on the opposite side you are cutting. FYI, BMW sells an M Performance shark fin Made of Aramid which looks identical to carbon fiber and does not affect any signals. I have installed one on a customer M5. |
chicagofan0019270.50 |
08-07-2022, 10:48 AM | #15 | |||
Rep 957
[/SIGPIC]
