03-31-2022, 11:06 AM | #1 |
Rep 176
BMW F30 N55 X-Drive 8HP70 vs 8HP75 Upgrade
Been digging around and it seems like most of the information is very outdated, but there's lots of videos of people upgrading to these transmissions on their E series.
As I'm heading towards 750+whp on a built N55, I need to start thinking about the drivetrain. The car is an 8HP45. Has anyone achieved these upgrades? Preferably the 8HP75 of course as it's the 2nd gen with a bit of extra torque rating, but I'd also like to know which one has more aftermarket development, and which one will be a better fitment and experience. Thanks guys! |
03-31-2022, 06:00 PM | #3 |
Rep 779
Def look into Pure Drivetrain. They are currently building me a trans for my F32. I was bored the other night and took a drive to their shop. The building does not say Pure Drivetrain anywhere on it. What it does say is PRO TORQUE, the famous torque converter company. So I am sure my trans, and yours will be in good hands. They had about 25 cars at Texas2k and their instagram is chock full of videos of their cars, and the build process of the trannys. Highly recommend.
https://www.puredrivetrainsolutions....tage-1-package |
04-01-2022, 05:18 PM | #5 |
Rep 779
Did you look at the link? They build performance transmissions, they do not help you swap other transmissions into cars they never came in. They have a ZF8HP45 that can hold 1200hp and 1000lbft of torque. You don't need more than that I am sure of it. Why would you even want the hassle of coding and all the other bullshit when they can build you a unit that is a direct bolt in, no putzing around.
04-01-2022, 08:42 PM | #6 |
Rep 176
Because the 75 is not just a physically stronger transmission, but it's also a newer generation. I was just wondering as I've been seing videos of swaps, and there's one of the 75 on an E series. Besides, it'd be a whole lot cheaper to not go with a built transmission, and just adapt one that will hold the power you need in stock form, for $1500 for a practically new 75 tranny, while they're asking for 10k with a bring your own core to build it.
https://www.ebay.com/itm/33431362954...hoCvk0QAvD_BwE But at this point I'm just trying to see all the options |
04-01-2022, 08:53 PM | #7 |
Rep 1,148
100% go with pure.. they're some of the best in the game, Ya it's money but it's money we'll spent. As said above, why hassle with coding and potentially problematic shift points/patterns. Newer gen trans or not, when they're done, it'll be incredible and exactly what you want. You're only going to get so far with shift speeds/line pressure so newer gen or not you're limited to what coding is available
Trans you linked is gonna need a custom adapter plate, mount most likely, and a whole bunch of other odds and ends, trans cooler lines may not line up, custom adapters, converter may need modification for an adapter plate to work, coding, output flange, wiring harness connectors etc etc, just spit balling here, spend the extra cash and have a bullet proof plug and play system |
04-01-2022, 10:18 PM | #8 | |
Rep 176
That's what I'm trying to figure out as these swaps are becoming more common. |
04-02-2022, 05:22 AM | #9 | |
Rep 779
I think OP is partially delusional on his power output numbers. I linked him to a stage 1, 6k dollars, and he claps back about not spending 10k on a tranny. You do not need the stage 2. You will need a fully built N55, including a worked over block, to come even close to 1000hp on an N55. Just about everyone on this forum would be sufficient to have a stage 0. Even big boost cars, stage 0 would do it. Last edited by LA1Z24; 04-02-2022 at 06:05 AM.. |
n55david1297.00 Pussiwillow522.00 |
04-02-2022, 09:39 AM | #10 | |
1297
Rep 3,536
Polo088161614.50 |
04-02-2022, 10:37 AM | #11 | ||
Rep 1,148
n55david1297.00 |
04-02-2022, 02:09 PM | #12 | |
Rep 176
Here's what I meant about these swaps, please use only up to date info, not stuff that was posted years ago. TurboLamik is selling kits for E series, that includes the plate, their custom TCU, and wiring harness. Look up their youtube channel for more up to date info. There's also the 0 to 60 channel who has been uploading his progress and just uploaded a video of the 70 tranny running on his n54. Skip to the 14 minute mark, or go through the whole series for more accurate info: https://youtu.be/uhDCplIJUmc What I'm looking for is info related to the F series, as it seems like you may not need a controller and shifter, hopefully just the adapter plate, because the 70 comes on the diesel version of the F30. |
04-02-2022, 02:33 PM | #13 | |
Rep 176
Here's the link for your own benefit, it bolts right in with the adapter plate and a few other parts: https://f30.bimmerpost.com/forums/showthread.php?t=1887697&highlight=8hp70 The benefit, is that you now have something that is almost stock, done by real engineers, instead of just patching things with a "built" transmission that all they did was "upgrade" the clutches, and a few things here and there. This transmission is physically bigger and stronger, you're going from a 450nm tranny that has been holding 600+nm, to one that was rated for 700nm, and that is known to hold over 1000nm, completely stock. The 75 is what's being used on M cars, so the BMW tunning is there |
04-02-2022, 03:34 PM | #14 | |
1297
Rep 3,536
Happy you found the info you wanted tho
imperfectluck428.00 |
04-02-2022, 04:15 PM | #15 |
Rep 421
@bimmerace no offense but how are you comparing a built tranny from a reputable company not knowing the exact specifics of what they upgraded and more importantly if they chose to upgrade the clutches only hypothetically speaking, the reason why they chose to do so?
If you didn't directly swap an M engine in your car, your built motor that wasn't built by BMW engineers, why did you choose to build it and not just take an M tranny and M engine and mate them together? There are of course obvious reasons why but the point I'm trying to get at without stirring the pot is that your opinion on Pure's built tranny meanwhile your plans are to run a built N55. I could give you more credit if you had actual BMW engineers work with you on building the engine but please don't assume just because the tranny wasn't built by BMW that it's a skeptical product. I'm a person that likes to know why people do things and if they provide me with valid data, who am I to assume / care the title that hangs over their head? |
04-02-2022, 04:55 PM | #16 | |
Rep 779
Pussiwillow522.00 n55david1297.00 |
04-06-2022, 04:27 PM | #17 | ||
Rep 124
The misinformation is hilarious, that was my car. To be clear I did not complete the swap and immediately sell the transmission. It was in the car since july of 21. Never gave me an issue and ran great. The confused individual that commented in my thread owns a m140, runs a different map due to his platform and was complaining about shift speed, did not want to contact RBT, and preferred to ask people on the forums with different setups what was wrong with his car. Bimmerace, My two cents the HP70 will work great depending on your power goals and can also be built in the future. It is a real option for big power that has been tested not just by me but also by Peter @ pureturbos and Steven @ Wedgeperformance. If you've got the cash go for a stage 1 hp45 or above if you want a no fuss, plug and play option. LA1Z24, a tip, don't go asking people for help on removing a transmission in a pm and then go calling their build a failure.
IG @jq_f22
04-06-2022, 07:40 PM | #18 | |
Rep 779
04-06-2022, 08:59 PM | #19 | |
Rep 124
IG @jq_f22
04-07-2022, 04:00 AM | #20 | |
Rep 779
Hey man. I recently popped 6th gear on my zf8 running e75. First I was like no biggy I'll buy your setup and be good to go. Then I saw its been sold! So I've decided to have a Pure Drivetrains trans built for myself. I am an auto mechanic. I was curious how easy it was to get the factory transmission out. I know there is a special tool to remove the driveshaft from the differential. BMW instructions state to leave the shaft attached and to just tie it up. Sounds like a pain in the ass to work around. How did you go about that? Any tips on getting the trans in and out? Thanks I appreciate your time. That is the whole message. I implore you to explain how this message makes me a fool. |
