04-03-2022, 12:59 AM | #1 |
Rep 11
2015 f32 need opinions on to tune or not
I currently have a 435i at 71k miles with an upgraded CP, and I put in an order for a catless DP and FMIC. Im not really looking for HP or Torque gains and would still like to have some reliability. I originally got just the DP because I plan on opening the whole exhaust system up eventually, however I also ordered the FMIC because I am expecting that tuning the car with the downpipe with a tune like BM3 would be better for the engine than just installing it and letting it run rich with no tune.
What I'm trying to ask is should I go with stage 1 BM3 or would it be better for the engine to run these mods with no tune? |
04-03-2022, 09:14 AM | #2 |
Head Fry Cook at McBurgertown
507
Rep 1,005
My take, simply based on your comments:
1. You're going to need/want a tune with that DP; otherwise, you'll be staring at a CEL non-stop. 2. MHD Stage 1 would probably better suit your needs; MHD tends to be less aggressive than BM3. 3. If HP/TQ numbers were your goal, I would opt for BM3 instead. |
04-03-2022, 02:03 PM | #3 | |
Rep 7,622
IC is always a good choice, same applies, fine for stock tune. Bottom line - tune is entirely up to you. BM3 and MHD are both reliable, and it would be a little strange to leave so much power on the table and run stock tune with hardware upgrades, but nothing is wrong with it. You will get a CEL with catless DP as noted above, and both tunes can remove that for you. |
