04-03-2022, 07:35 AM | #1 |
Rep 104
Acceleration problems.
Got BM3 installed almost 2 months and the intercooler was installed 1 month. Everything was working fine.
Yesterday morning, when accelerating, it was like driving a minivan. I can hear the turbo kick in but no pull but slowly accelerate. The turbo sounded like blowing with a big fan inside a room in my engine bay(Prior I didn’t hear that before). Feels like the car is drowning in the water when driving. It will stall at 55mph and accelerate again if I step hard on the gas. The mechanic changed the top gaskets due to leaks near the spark plugs area but not the round thing on top of the engine bay. No error code so far. My mechanic is closed.
F30 335i xdrive
04-03-2022, 11:59 AM | #2 |
Rep 529
Def check the round thing at the top of the engine bay 😂😂😂😂🤦*♂️🤦*♂️🤦*♂️
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
04-03-2022, 10:00 PM | #4 |
1297
Rep 3,536
Yep, boost leak
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
04-04-2022, 08:56 PM | #6 |
Rep 104
I am going to my mechanic tomorrow morning due to work today. Hopefully is the connectors like everyone said which I just changed the IC.
Thanks guys!
F30 335i xdrive
04-05-2022, 12:20 AM | #7 |
Rep 5,776
As mentioned, sounds like charge pipe or boost leak. I've had a charge pipe fall off and the car will sound loud and run like a weak 4 cylinder. I would look into what that round thing is, though.
04-06-2022, 04:57 PM | #8 |
Rep 104
Found out it is the Boost Leak like everyone is suggesting. You guys are the best!!!!
Its from the large hose clamp from the pipe below the throttle body. Probably from installing the IC, the mechanic loose that. Mechanic tried 2 times and still popped off. I tried it made sure the bottom is secured and still popped off after hard acceleration. https://www.vr-speed.com/vrsf-charge...0-f30-n55.html From the site it says 3". I probably go to HomeDepot and get a cheaper stainless clamp. https://www.homedepot.com/p/3-in-4-i...595P/317775012 The round thing I was talking about is the PCV valve which is functioning fine. There are youtube videos like 1 below shown that we can cut and replace with amazon one. The mechanic said my car is different and that has to change the whole top part...
F30 335i xdrive
04-06-2022, 06:00 PM | #9 | |
Rep 7,622
04-07-2022, 04:10 PM | #10 |
Rep 104
thejeremyman9 Thanks!
I took your advice and had my mechanic take the whole CP out and reinserted again on the plastic part. This time is all the way in. Hopefully this time it will last. VRSF....they don't warranty the plastic coupler and T-Bolt clamps. If this time still has a problem, I will go with a different brand.
F30 335i xdrive
