04-07-2022, 09:31 AM | #1 |
Rep 121
Disappointing first public charge
Today is the first time I have ever had to use a public charger.
Drove 110 miles from full charge Turned on battery preconditioning 15 mins before arrival Connected up to a BP pulse 150KW CCS charger Outside temp is 12C Currently 27 mins into charging and speed sits between 31KW and 33KW Anything obvious I have overlooked? |
04-07-2022, 10:37 AM | #2 |
Rep 47
Have yet to use a public charger so unable to help in guidance.
Can understand your disappointment after finding a 150KW charger. Will be very interested in the replies |
04-07-2022, 12:20 PM | #3 |
Rep 42
I doubt there is anything you've overlooked, it is sometimes luck of the draw whether the charger is functioning correctly.
Take a look for the charger on zap map and see if anyone else has reported issues as it might just be a dud charger. I had similar at an IONITY but when I switched to the charger left to it my speed shot up to >100kwh |
04-07-2022, 03:35 PM | #5 |
Rep 247
I think you need to enable the preconditioning much earlier, at least 30 mins before charging. Also if you state of charge was >50% you won’t get close to 150kW, more like 75kW. You need to run the battery soc lower
https://insideevs.com/news/501674/bm...ging-analysis/ |
04-07-2022, 07:42 PM | #6 |
Rep 121
My SOC was 48% when I started. Charged for 47 mins and remained at 35KW throughout. Multiple ZapMap reviews complained about this charger being slow so maybe that was the issue..
Return trip I stopped off at a gridserve charger - 125KW. SOC was 44% and I had a 20 min charge at 44KW. Both charges today did not change in power output. The finishing charge was identical to the starting charge… |
04-08-2022, 06:30 AM | #7 |
Rep 852
They advertise the speed as “up to”, so I don’t think there will be any discount forthcoming. Plus the price in the U.K. is per kWh used. On the continent, so chargers are priced per minute you are connected.
04-08-2022, 11:38 AM | #8 | |
Rep 126
As you see the lower your SoC at start, the higher the efficiency in charging |
04-10-2022, 03:38 PM | #9 |
Rep 601
Also, remember, BP's chargers are awful as a rule. Never had a decent speed charge off them, the 50's give 35, so do the 150's. They balance the load on their infra at sites a lot in my experience, so if there's anyone else charging or it's a 'peak' time of the day then good luck.
04-11-2022, 02:38 PM | #10 | |
Rep 40
04-12-2022, 03:51 AM | #11 | |
Rep 852
04-15-2022, 07:54 AM | #12 |
Rep 366
Chargers and banks of chargers are often sharing an upstream supply with a current limit that they have to share and manage between them.
Some brands (Tesla for example) have strict rules on the installation to protect their brand and will spend a lot on the electrical infrastructure (even mini-substations) to ensure all the Superchargers will perform within a tolerance of their advertised performance. Other charging brands will just use whatever infrastructure is available, which at a commercial premises will likley be a standard 3-phase commercial supply which may even be shared with the commerical premises itself. If so, the current draw has to be monitored and managed between all the consumers. So reports of 'faulty' chargers that do not routinely perform to their advertised speeds are often not faulty at all, they are just unable, by the design of the installation, to perform to their max level unless the conditions are 'perfect' - i.e. you are the only car charging and the rest of the usage on the local supply is low. You can often get a good idea of the ability of an installation by how much work has been done - if it's a brand new Ionity installation with a massive sub-station transformer next to it, then you've got a good chance of a full speed charge. If it's a small installation shoved at the edge of a garage forecourt or supermarket car park, then probably not, unless the conditions are perfect. Last edited by supersebbo; 04-15-2022 at 08:02 AM.. |
HighlandPete6658.50 |
04-15-2022, 05:12 PM | #13 | |
Rep 15,858
This is my understanding. I'm aware of a 3 charger installation where the first car can get a decent charge, but add others... the 2nd and 3rd are therefore cut back. Power supply to the installation is limited, it is as simple as that. |
04-16-2022, 03:32 AM | #14 |
Rep 40
Thanks for the tip never even thought about reinitiate when came back to car after walk on that occasion dint have time to wait to charge again, So in future will wait and double check before walking of to give it time to charge.
