BMW 2 Series Technical Topics (G42) Cosmetic Modifications (Exterior, Interior, Lighting)
      04-10-2022, 07:31 AM   #1
BeemerBaron
M Performance Carbon Fibre Interior Install G42
So I decided to install the M Performance Carbon Fibre Interior in my 2022 M240i G42 and did a quick installation video for anyone looking to do the upgrade themselves.
Appreciate 17
      04-11-2022, 06:41 AM   #2
bmwloverm2
Drives: BMW M240i 2022
Hi Slingray
Thanks for the video, gotta say this is one of the most calmed, well filmed, edited video I've seen about a DIY in quite some time.
Just bookmarked it, since i'm considering to do this change of trims in the mid term.
      04-12-2022, 01:40 AM   #3
BeemerBaron
Originally Posted by bmwloverm2 View Post
Hi Slingray
Thank you mate, much appreciated I wanted to ensure it was useful for someone looking to perform the medication without doing any damage to their beautiful BMW interior in the process. Hope it helps!
      04-13-2022, 09:28 PM   #4
AndyTurboI6
Drives: 2022 BMW M240i
This is very useful, thanks very much for putting this tutorial together.
      04-20-2022, 08:41 PM   #5
OzHatter
OzHatter's Avatar
Australia
18
Drives: 2020 BMW M2 Competition
Slingray I'm trying to order this kit for my AU M240ix and the parts guy is very nice but a bit clueless lol. Can you confirm the part number? Looking at the M340ix on RealOEM I believe I should be ordering: 51952466892.
      05-03-2022, 07:38 AM   #6
DaveDee
DaveDee's Avatar
556
Drives: BMW X5M Comp
Great video ad thanks for sharing. Are you able to say if the strip in the passenger side section is removable from the rest of the trim?
      05-04-2022, 03:33 AM   #7
BeemerBaron
Orderd from paddleshifterz (dot) com:
"M Performance Carbon/Alcantara Interior Trim Kit"
Part number wasn't listed unfortuantely
      05-04-2022, 03:35 AM   #8
BeemerBaron
Thanks Dave.
To memory I'm confident it could be separated, it would be fiddly and but quite sure it can be done.
DaveDee556.00
      05-04-2022, 03:47 AM   #9
DaveDee
DaveDee's Avatar
556
Originally Posted by Slingray View Post
Thanks Dave.
Thanks for that
Just trying to rule in or out hydro dipping I've done a Stek PPF Dynagloss carbon on these parts and it looks good except the tetragon pattern comes through slightly.
I think that part in total would be a bit long for hydro dipping and need a lot of masking.
Probably easier to do it the expensive way the first time
      05-05-2022, 06:21 PM   #10
DriftKing860
Drives: Passat
FYI carbon fiber interior no longer a port option. Thats what my CA told me today. We could not add it to the order.
      05-07-2022, 11:50 PM   #11
OzHatter
OzHatter's Avatar
Australia
18
To quote myself lol, I ordered and fitted the kit with part number 51952466892. The only difference I think is that this kit has integrated light bar for the 3 & 4 series which sadly our little 2er does not have the wiring for. Other than that, it all fits perfectly!
Before:
[IMG]
View post on imgur.com
[/IMG]
After:
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
However, one problem. I disconnected the battery before fitting the dash trim since there are a bunch of electronics in it for the ventilation controls. Now I have a warning for park assist being unavailable. Do I have to carry out some sort of reset due to the loss of power, or am I booking the car in to have it investigated?
Edit the parking sensor error was very simple
To fix, the steering needed recalibration. Turn the wheel full lock left, then right and it will give a little "nudge", centre the steering and all good again why can't the idrive error message be more clear?
DaveDee556.00
      05-08-2022, 04:29 AM   #12
BeemerBaron
Before:
[IMG]
[/IMG]
After:
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
Looks great! Big improvement. Don't even notice the area for the lighting.
Glad you got the issue with the parking sensors sorted. The other option if you ever have rogue errors codes is to use an app like BimmerCode (which clears errors after a code) or if the error code is a bit stubborn BimmerLink should sort it. There's so many sensors in these modern car's, it's easy for them to get themselves a bit out of whack and throw a code without there being an actual underlying issue.
Congrats on the install, the CF looks great.
      05-08-2022, 10:37 PM   #13
OzHatter
OzHatter's Avatar
Australia
18
Cheers! Good tip on using Bimmercode to check or clear errors, hopefully I would get something more senslbe than the idrive error message.
The CF install was a breeze thanks to your excellent tutorial video
      05-19-2022, 10:25 AM   #14
BeemerBaron
You're welcome mate! Enjoy the new interior.
      06-11-2022, 10:46 PM   #15
whiteninjazx6r
Drives: BMW M240i
Great video.
Do you plan to do the steering wheel trim? I can't find any video or info on the install. Any info would be much appreciated.
Thanks!
      06-25-2022, 10:19 AM   #16
BeemerBaron
Originally Posted by whiteninjazx6r View Post
Great video.
Thanks!
I am trying decide between replacing the entire wheel or jsut doing the CF upgrade.
I have a set of CF paddle shifters on the way in the meantime. I'll do a vid of that install if useful for someone.
      06-25-2022, 04:21 PM   #17
DaveDee
DaveDee's Avatar
556
Great video.
Thanks!
Here's a vid of the steering wheel removal (Kies Motorsport) where the paddles are changed on the bench but unlike others the wheel is removed. No wire harness or connector transplants are included.
Another good video by Evolve is a DYI on their paddles done without steering wheel removal.
      07-19-2022, 07:40 AM   #18
DaveDee
DaveDee's Avatar
556
Thanks Dave.
You are 100% right about the difficulty of removing the passenger side trim from the alloy frame, some plastic tags are melted over the catch to retain it. It certainly rules out hydrodipping
Your choice of carbon is the best way to go, after trying wrapping with Stek PPF and the considering carbon stick on parts I pulled the trigger on this kit and it arrived today (along with some sensational paddleshifters). The finish of the product is better than anything Iv'e seen before and am looking forward to doing the install.
Did you fit the small strip behind the compartment door? I'm assuming its a push in and lift the retaining clips.
The paddleshifters were about as good as they can get quality wise, they are a nice billet finish and looks like the PCB mounting plate is cast rather than the stock plastic
I'll include a pic here and write the installed paddles up in another post.We were chatting about these, they are expensive but worth every dollar from what I can see so far of the product
Also the vendor you mentioned, Szab at Paddleshifterz dot com could not have been more helpful or enthusiastic. Service was first class
Stock paddle included for comparison
Like the old saying "what will it be the scotch you'd rather drink or the scotch you would rather pay for"
It's certainly the case here
      07-21-2022, 08:15 AM   #19
BeemerBaron
Looks great Dave. - I did fit the small strip behind the compartment door and yes to memory you're correct, it was just 2 or 4 small clips holding it in place, it wasn't as tight to get to as it appeared it would. I might of used a trip tool to pop the original out if I recall.
DaveDee556.00
