2006 330i Build Thread
04-18-2022, 11:23 PM | #1 |
Rep 172
Documenting my build on my 06 330i AT here.
I bought the chassis with a bad engine, and transferred the subframes/transmission from my 06 325, and bought a used N52k with 70k to replace it. Goal is to build a reliable street car that also does well on the track, and can handle a lot of seat time without issues. I live in Arizona so emphasizing on efficient cooling. Here is what I've done so far- Tuning StageFP custom tune XHP st3 transmission flash N2mb wotbox Engine MILVS VTT crank bolt catch VTT crank seal guard VTT engine mount inserts E46 M3 transmission mounts Intake N54 intake manifold N54 throttle body US airbox with K&N filter, Dinan ram Ebay intake scoops Exhaust AA Replica headers 3" exhaust after 2nd cats Ignition Eldor Coil packs NGK Copper Cooling/Misc 90/10 Water/Antifreeze +1 bottle Water Wetter N54 oil cooler retrofit BMS oil tstat bypass Ebay BMS rep N54 catch can CCV delete Front Suspension Dinan camber plates on Z4 strut mounts M3 upper/lower control arms Megan front strut brace Koni yellow shocks Tckline coilover conversion kit Swift 336lb springs E90 M3 front sway bar Whiteline adjustable end links Rear Suspension Swift 672lb springs Rear E46 M3 bump stops Dinan Rear upper shock mounts Godspeed rear toe arms Vwetish diff brace Whiteline diff/subframe bushings 3,91 differential 335 axles 335 rear knuckles Braking 335 brake calipers r1 concepts slotted discs Bimmerworld brass caliper bushings Stoptech sport pads Stoptech SS brake lines Motorsports hardware stud conversion Next up on the list is -Sound deadening removal -Euro crash bars -Redo exhaust as a full 3" to the headers -S65 injectors +E85 remap -M3 rear camber links +Tckline DA shocks Thanks for looking A couple videos Canyon Driving Exhaust Clips Misc Photos Shout out to Biginboca for showing me how he made his silicone intake piping
I don't check PM, DM me on Instagram @rai_n52
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential Last edited by Raimund; 04-18-2022 at 11:40 PM.. |
04-19-2022, 12:43 AM | #4 |
Rep 172
This is true 😁 I have been looking into swapping a ZF6 gen2 or a ZF8 since its the daily traffic car 🙂
Thank you 🙂 330 ftw
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential |
04-19-2022, 03:38 AM | #5 |
Rep 2,738
Sweet build… love the rims!
04-19-2022, 03:08 PM | #6 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
Just curious on the 335 rear hubs; I had no idea they were different than the 330 ones.
The axles just bolted right up to the 330 diff?(were they manual or auto axles) |
04-19-2022, 04:23 PM | #7 | |
Art Collector
2427
Rep 3,450
Regardless, that’s a beautiful build. Very nice work!
04-19-2022, 04:49 PM | #8 | |
Rep 172
Thank you 🙂
I am not sure the differences in hubs, I just happened to use a full rear end dropout from a 335 and then used the 3,91 diff. I believe the 335 was auto I'll probably end up with a 2nd gen ZF6 unless I come across a sweet deal on a ZF8, but I'm hopeful 🙂 I'm sure I could make a ZF8 work as they came on the F series 528i with the N52.
Biginboca3766.50 |
04-20-2022, 02:05 PM | #9 |
Rep 172
Most of the sound deadening removed. About two hours of easy work for -14.5lbs lost. No noticeable difference in noise with the carpet still in. Just need to buy some adhesive remover to remove the residue. Still have about 3lbs to remove in the doors.
So far down -152lbs total For comparison, a Seibon carbon fiber trunk saves 10lbs for about $800 Edit: -17.2 lb total from sound deadening with doors. Rear section Front section
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential Last edited by Raimund; 04-22-2022 at 02:07 PM.. |
04-20-2022, 06:08 PM | #10 |
Rep 2,738
Reimond… great minds think alike
I also had my scale out today and was weighing parts as I took them off! What are the odds lol. I’m reluctant to go after sound deadening as of now I’ve been trying to stay away from anything interior or comfort related… which is really hard to do
Raimund204.00 |
04-20-2022, 06:20 PM | #11 | |
Rep 172
I had to make my car a little faster after you showed me your dragy time haha. I have a spreadsheet of all parts I've weighed if you ever need any of the info. I'm in the same boat as you too, I don't want to fully strip this one like I did the 325. The sound deadening removed with carpeting still in seemed like a good compromise.
Biginboca3766.50 |
04-21-2022, 02:13 AM | #12 |
Old Geezer
364
Rep 1,193
Drives: 08 E92 N53B30
My daily driver and weekend racer E92 weighs 3328 lb (1510 kg). CF hood, plastic fenders and rear seat removed.
I had to use rear 335 wheel carrier and half shafts so I could use brembo calipers. Rest of suspension is from M3 and KW V3 shocks. My N53b30 with N54 intake, supersprint headers and software modes puts out 297 hp.
04-21-2022, 07:36 AM | #13 |
Rep 3,200
Drives: E92 325i MSport Coupe
Good work Vlad! I'd love an SS manifold, but sadly they're only available for LHD markets.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-25-2022, 12:51 AM | #14 |
Rep 172
Well this happened. Started developing a wobble and went to replace the harmonic damper and the bolts were damaged and three snapped on removal. All other pulleys and belt are in good shape.
Talked to a few other people who had the same thing happen after installing a VTT crank bolt catch. (Installed as extra safety since engine was out and my last engines crank bolt backed out.) Asked VTT for their opinion and they just said it was fully my error. However I followed their directions and torque specs exactly, so not sure why they backed out. Good news is the crank is still spinning normally and isn't bent. So dealing with getting these bolts out before I can do anything else 🙂
04-25-2022, 04:37 AM | #15 |
Rep 2,738
Ugh that looks like a nightmare. Thee isn’t much room to get a drill in there either. What’s your plan? Remove the radiator and drill them out?
It looks like you have a crank seal shield on there also, and the bolt catch has been rubbing it. I wonder if that is part of what caused your issue.
08-06-2022, 09:46 PM | #17 | |
Rep 172
08-06-2022, 09:47 PM | #18 |
Rep 172
08-06-2022, 10:02 PM | #19 |
Rep 172
Update
Update on the build-
Had a big headache and wallet empty with that crankhub issue and left everything alone for awhile. Finally back to modifying things again. Here's what's new Scored a free msport front bumper, has some damage and needs a respray View post on imgur.com Installed a 3 stage intake manifold after someone asked me to dyno the n54 mani vs 3si with headers/milvs/sfp tune. Ended up leaving it on for a few months now as I'm still waiting for a revision from Bob to get it on the dyno. The low end torque is nice around town but definitely lacking at upper rpm vs the n54 mani. View post on imgur.com Slotted strut mounts with a dremel and deburring attachment for an extra -0.3 to -0.5° of camber. Going to run -3.8 camber up front with zero toe. Was at -3.5 and 1/16 total toe. View post on imgur.com View post on imgur.com Fully removed any remaining sound deadening tar with a heat gun and a plastic scraped. Followed up with 3m adhesive remover . This worked much better than the dry ice I used on my last E90. Current weight is around 3260lb no driver. View post on imgur.com Some more hidden weight reduction -5lb View post on imgur.com View post on imgur.com Had the exhaust redone. AA headers to oem 2nd cats, oem resonator, 135i n54 muffler. This sounded pretty good, but then I removed the secondary cats and the rasp and smell were pretty bad. View post on imgur.com Sound Clips- https://www.youtube.com/watch?v=fw5eE7q3RJ0&t=6s https://www.youtube.com/shorts/XU9GBSCNgcI Going to reinstall 2nd cats and run a magnaflow muffler as it's 17lbs lighter than the 135 one. Coming up soon- M3 master cylinder and new brake booster. Master cylinder seal and booster are leaking so replacing with the m3 one for a supposed more linear pedal with shorter travel. NRW paddle shifters View post on imgur.com Also, does anyone know how to upload photos inline with the text on a post without them coming out massive? imgur and then linking the image addres with /img makes it obnoxiously large, and add attachments directly just adds them all to the bottom of the post
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential Last edited by Raimund; 08-06-2022 at 10:29 PM.. |
Biginboca3766.50 |
09-26-2022, 07:15 PM | #20 |
Rep 183
Drives: 2008 Bmw 328i Coupe
Small suspension question, why the z4 front strut mounts?
09-26-2022, 07:17 PM | #21 |
Rep 172
The z4 strut mounts are shorter, so they allow more shock travel at any given ride height vs an e90 strut mount.
This is also why most camber plates are designed as short of a stack as possible
09-26-2022, 07:27 PM | #22 | |
Rep 183
