04-20-2022, 01:56 PM | #1 |
BimmerPost Supporting Vendor
160
Rep 275
Studio RSR - Vargas (VTT) V2 Crank Hub Special
What's going on everyone, Richard from Studio RSR here in Orange County, Southern California.
I just wanted to offer our Crank Hub Special to forum members and your friends. $2000 OTD with Crank Bolt Capture - NGK Spark Plugs 97506 +$160 - Shipping also available Also included: - Oil Change with Motul 8100 - Coolant Flush - Front Main Seal - Vacuum Pump Cover - Crank Bolt - Cam Gear Bolt - Oil Pump Sprocket - Wishbone Chain Guide - Valve Cover Gasket Please feel free to reach out to me directly by email or phone and I can get you taken care of. Email - StudioRSRrichard@gmail.com Phone - 844-991-5582 Ext. 705 VTT is proud to offer the only complete N54, N55, S55 complete crank hub solution that does NOT require the crank to be drilled for pins. Our hub uses our proprietary “Spline Lock” technology that uses high tolerance machined splines that press into the crank, and positively lock the hub to the crank. We spent many months testing, and retesting this design, utilizing well over 10 different samples to come to our final production version. During testing, our final hub managed to break our testing rig before slipping. These have been bench-tested, and real-world testing on the VTT N54 race car spinning 8K RPM and making well over 900WHP. This technology means our hub installs the same as a stock hub, with no drilling of the crank, which means MUCH less labor is involved and is reversible is ever wanting to be uninstalled leaving no holes in the crank. The “Spline Lock” is ONLY available with the VTT Crank bolt capture for the ULTIMATE Crank Hub solution for your BMW. These parts are designed to be used together, and the spline lock should not run without the CBC VTT “Spline Lock” Crank hubs are CNC manufactured from 440C tool Steel with a Rockwell rating of HRC60 for the ultimate in durability, and toughness.
Rhythm | Speed | Racing
www.studiorsr.com | email: info@studiorsr.com | call: 1-844-991-5582| Instagram: @studiorsr| StudioRSR G8x M3/M4 YouTube videos For updates on your order, please email updates@studiorsr.com Last edited by StudioRSR; 04-20-2022 at 04:09 PM.. |
04-25-2022, 12:56 PM | #2 |
160
Rep 275
www.studiorsr.com | email: info@studiorsr.com | call: 1-844-991-5582| Instagram: @studiorsr| StudioRSR G8x M3/M4 YouTube videos For updates on your order, please email updates@studiorsr.com |
04-26-2022, 05:08 PM | #3 |
160
Rep 275
Last week of the Driver's Mod Sale, get your deals locked in before it's too late!
04-29-2022, 03:56 PM | #4 |
160
Rep 275
05-06-2022, 08:17 PM | #5 |
160
Rep 275
:BUMP:
05-25-2022, 07:00 PM | #6 |
160
Rep 275
06-30-2022, 12:42 PM | #7 |
160
Rep 275
Bump!
