Washer Jets - Hot or not
12-07-2008, 05:03 PM | #1 |
Rep 168
Drives: 335D SE Touring
I left my car in a hotel car park near Marlow last night and this morning, my windscreen washer jets were frozen solid (it was a few degrees below zero last night) when I set off in the car this morning.
Now clearly my washer fluid mix is not strong enough but it beg the question, are the washer jets heated on these things. Now I know that my headlamp washers are heated because I have Xenons and it is a legal type approval requirement but what about the windscreen? Am I making an incorrect assumption? |
12-07-2008, 05:40 PM | #2 |
Rep 1,130
They should be heated, mine take a while to get going, but if its just water (v dilute soln) in the bottle and nozzles then its likely to take longer to melt and defrost.
12-07-2008, 05:51 PM | #3 | |
Rep 9,218
12-08-2008, 02:20 AM | #4 |
Rep 8,095
They are heated, on mine anyway. This doesn't really help overnight freezing though when the reservoir or the fluid in the pipes freezes - the heated jets just prevent refreezing due to wind chill.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-08-2008, 02:32 AM | #5 |
Rep 168
OK
Well I did have (what I thought) was a good quantity of washer fluid in the bottle so it wasn't just pure water. So the next question: How do you turn them on? Are they automatic? Do they come on with the heated rear screen? Do I need to say the magic word? Thanks |
12-08-2008, 02:33 AM | #6 |
Rep 8,095
On all the time.
Ian
12-08-2008, 02:49 AM | #7 |
Rep 168
12-08-2008, 02:50 AM | #8 | |
Rep 9,218
The e90 ones only seem to free up once the engine is good and warm. Mine have also refrozen a couple of times when driving through freezing fog. One of the 'steps backward' that BMW made with the e90 generation, which also include the door and boot opening warning that only operates AFTER you have driven off and the heated wing mirrors that only switch on AFTER you have activated the rain sensor so that your wipers drag over a frozen windscreen. |
12-08-2008, 02:51 AM | #9 |
Rep 8,095
They quite possibly are, they're just not all that effective. They weren't on the e46 either.
Ian
12-08-2008, 12:23 PM | #10 |
Rep 445
Hmmm, mine have frozen each time and took ages to work, was almost at work by the time the fluid came through, I assumed they weren't heated. How to test?!?!?
2014 [14] M135i, 3dr, MG, Auto, SP, CP, HS, HK and FBP
Recent Past..... 2011 [61] Abarth 500, Funk White, Leather, H&R 2007 [57] 320d M-Sport Touring Pre 2007 - GT TDI 4MO, Mk4 R32, A3 TQ, A3T, Cupra R and on and on and on..... |
12-08-2008, 04:56 PM | #11 |
Rep 7,519
Drives: 2009 E90 335i MT
Wind chill does not affect metal or plastic, only flesh.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
12-08-2008, 04:59 PM | #12 |
Rep 7,519
Anything's better than the washer system I had on a 1970 Plymouth Valiant. There was actually a bellows type foot pump next to the brake pedal. Sometimes, on really cold days, the pump itself would be frozen.
12-08-2008, 05:22 PM | #13 |
Rep 1,733
01-01-2009, 03:43 AM | #14 |
The Toy Collector
Rep 19
Drives: 08 320D SE E90
Garage List 2008 320D SE E90 [0.00]
2004 Harley-Davidso ... [0.00] 2003 Yamaha XJR1300 [0.00] 1967 Chevrolet C-10 [0.00] 1998 Chrysler Grand ... [0.00] 1971 Oldsmobile Cut ... [0.00] |
They are heated, sometimes on a cold day you can see the water steaming after it is sprayed onto the screen.
Saying that mine have still frozen (again 2 days ago) when it is really cold.
2008 BMW 320D SE (177) E90
01-01-2009, 04:33 AM | #15 |
Rep 7
A word or warning with regard to windscreen washer concentrate, when I had my E90 330iSE I used cheap washer concentrate from Halfords which, over a period of a few months, clogged-up the system completely so that the screen washers stopped working.
I took the car to the dealership to have it put right and straightaway they asked me if I'd been using genuine BMW concentrate or an 'inferior' alternative? There was much tutting when I confessed, followed by an £70 bill to strip the system and flush it out. I've stuck to the genuine product ever since! |
01-01-2009, 04:47 AM | #16 | |
Rep 89
E 91 335d SE
Sparkling Graphite, Grey leather, Sat nav, Adaptive and High beam assisted Xenons, Electric heated seats, HiFi Speakers, Burr walnut etc. For winter - Defender 90 county. |
01-01-2009, 07:17 AM | #17 |
294
Rep 2,602
Always thought that the heated jets and mirrors were activated based on the outside temp...
It is more likely that the fluid in the pipes has frozen, given their size and the small amount of fluid in them though. Never heard of the mirrors warming up after the rains sensor has been activated. Mine certainly don't! Maybe it's been changed on later vehicles? |
01-01-2009, 07:41 AM | #18 |
Rep 584
As above, jets come on when the mirrors do. Its down to outside temp, or defrost activation. They only stop the jets from freezing, not the fluid contents in the pipes/bottle. This has always been thus.
01-01-2009, 11:31 AM | #20 |
Diesel Head
12
Rep 550
Well we where at -7 the other day and washers where working ok, both the headlamp and window screen. I'm guessing mine are heated however i've never checked the spec.
