04-23-2022, 06:17 PM | #1 |
Rep 340
Swift springs for Öhlins front struts | get more clearance
For sale are a pair of swift springs I used on my previous set of Öhlins Road & Track setup. Specifically, these are shorter 7" springs to move the lower spring perch higher (~19mm) to create additional clearance for wider wheels and tires. Per usual Springs are located in Austin TX Buyer pays shipping/fees (if applicable) Details Swift p/n: Z65-178-100 Rate: 10kgf/mm (560lb/in) Length: 7" ID 65mm: (2.56") Please note Raising the perch while keeping the spring captive requires the lower perch to be at the end of the threads—the only downside is in some instances corner-balancing may be difficult or impossible. I chose a higher rate, but there was not a significant difference in ride or performance. Here is an image showing clearance with the swift springs. Wheel size 18x10 +15 Tire size 275/35-18 Goodyear Supercar 3 Ride-height is a bit lower than Öhlins' suggested height. |
