04-28-2022, 12:35 PM | #1 |
///M
120
Rep 108
Drives: 2023 M3C (due May)
M4 Lag?
I've owned and loved my E92 (manual) and F93 (DCT). No complaints, and miss my V8.
I'm currently debating between an i4 M50 and G80 Competition. I had a chance to drive a 2021 G82 Competition last week, and I was shockingly disappointed. When I was cruising (70mph or more), when I floored it, there was a significant delay (up to 1 second) before the car took off. I knew it couldn't be turbo lag, and after playing around, it is the delay from going from 8th gear down to 6th. I tried all the Sport, Sport Plus, and M modes. Nothing seemed to improve it. On my F83, when I put it in M mode, it would automatically downshift to anticipate me driving more aggressive. Before I commit to the i4 M50, is there something I'm missing? Is the delay in downshifting expected? |
04-28-2022, 12:50 PM | #2 | |
Rep 148
The S58 is designed to deliver power at the top end. |
04-28-2022, 01:24 PM | #3 | |
Rep 2,306
Electric cars (except taycan) only have one gear. Hard to beat the immediacy of the power delivery of EVs
2001 330Ci (sold)
2007 335i (sold) 2008 E90 M3 (sold) 2015 M3 (sold) 2022 G83 |
04-28-2022, 01:31 PM | #4 |
Rep 435
Car and Driver wrote about highway passing speed: "The i4 M50 takes advantage of its all-wheel drive and the instant torque from its electric motors, though, going from 5 to 60 mph 1.0 second quicker than the M3. Our test results also show the gap in passing speeds, with the M3 requiring an additional 0.9 second to go from 30 to 50 mph and an extra 0.7 second to get from 50 to 70 mph."
https://www.caranddriver.com/news/a3...tition-tested/ |
04-28-2022, 01:32 PM | #5 | |
///M ♥ Recycled Dinosaurs
3212
Rep 1,781
Drives: BMW M4, BMW X5 45e
You appear to be shifting gears yourself because the car would never select 8th gear in Sports Plus at 70 mph (or even much higher speeds). The 8th gear is a tall, "efficiency" gear ratio. Next, the modes are not a clear way to know for sure what you are experiencing because Sports Plus in my car can be configured with the most aggressive shift setting which it could be at its mildest in the car you drove. Assuming Sports Plus and most aggressive shift setting, you wouldn't experience a whole lot of delay at the speeds you're mentioning because the car should be maintaining a 3.5k to 4.5k rpm by itself and shouldn't need to downshift at all. Now if you're playing with shifts yourself prior to flooring it, it's operator error again because you need to be able to anticipate what you need a few seconds into the future (and 1 second is the bare minimum). The only time I experience delay is if I'm in comfort, cruising around and then suddenly request Sports Plus levels of performance. There are two gear shifts down required and the time taken to take the engine up to 3.5k-ish rpm. The failure there is my inability to have anticipated the need for it.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
12
GixY2K517.00 jimbethesda1857.50 Mark Kez2201.50 NightWriter4844.00 DavidXJ664.50 DocWeatherington2943.50 Der_Wolf888.00 farfugnugen66.50 Bimmerfun827457.00 ferrarifast640.50 pateke267.00 UpperArmMonkey4.50 |
04-28-2022, 01:55 PM | #6 |
Rep 570
Drives: '19 GLA45AMG(his) / '21 X3M40i
I suggest using transmission setting S3 and not S1 or S2 while in S+.
In my opinion, this car couldn't be more jumpy with the setting described above. The response time is the best I've experienced.
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 |
Tyga113255.00 BMWRacer5232520.50 |
04-28-2022, 02:22 PM | #8 |
Rep 1,612
Yeah - I mean, that's literally one of the highlights of this car. You can beat virtually any car from a 70 roll except super cars.
04-28-2022, 02:58 PM | #9 |
///M
120
Rep 108
Thanks
Thanks everyone. I've owned two M cars, but the electronics were a bit different then my F83. I'm guessing whoever drove the car previously had S+ in S1, and I didn't think to check that.
I agree, my F83 would downshift when I was in S+ mode, so for the G82 to remain in 8th gear seemed very odd. Still debating. I love the thrill and growl of an M. |
04-28-2022, 03:10 PM | #10 | |
Rep 2,306
We (or most of us) are talking about transmission settings. That's D 1,2, or 3 (automatic) or S 1, 2, or 3 (sequential aka manual). The D settings determine the logic behind the car changing the gears for you. D3 holds the gears longer vs D1 and D2 is in between. The S settings just change how quickly the car switches gears once YOU tell the car to shift. Sounds like you were in S something? Maybe? Anyway, to avoid the downside of auto mode, you should be is S (I like S3). About to "floor it"? Make sure you're in the correct gear first. It's also possible I have no idea what you're talking about, so my apologies if I am.
2001 330Ci (sold)
BMWRacer5232520.50 YamaLink425.00 |
04-29-2022, 04:39 PM | #11 |
Rep 609
I have never been in 8th gear in Sports Plus. I can shift there at 75-80, but it downshifts to 7th in a few seconds when it goes back to D. I find punching it at 70-100 shifts immediately down 3 gears at 70, 2 at 100. Zero lag. From idle, the 'max' torque is available at 2750. It does take a second to get there, but after that, the power is instantaneous--and I come from 6.2 liter NA V-8s. I suppose your results can vary, but if I want instant off the line torque, that's what launch control is for and why it is set in my M1 button.
GixY2K517.00 |
04-29-2022, 04:45 PM | #12 |
salty cowboys fan
6191
Rep 3,420
It's possible to keep it in lower gear once you're familiar with the settings, but even so response will never compare to an EV, that's their party piece
she’s home! '22 M4 Comp xDrive
Vishal500281419.00 |
04-29-2022, 04:58 PM | #13 |
Rep 305
Get an g8x and you will love it.. in the end it's the best sports car/sedan out there before getting into a Porsche 911 turbo s or gt3, cayman gt4rs imo… EVs are super boring, I have driven em all..
PinkFlamingo264.00 |
05-01-2022, 12:12 PM | #15 | ||
Rep 516
Do I care? No: downshifting gives me something to do in a world in which software tries increasingly to do everything for us in advance.
Current:
F90 M5 Competition Previous: G20 M340i G20 330i M Sport |
05-02-2022, 06:27 AM | #16 | |
Occasionally frequent poster
3005
Rep 2,745
Of course, you all do realize that the solution to this issue is to buy the base model, with the proper manual transmission. Then there is no confusion at all between car issues and operator error. Use the paddles, and downshift before you need to accelerate. The turbo will spool up and the response will be instantaneous.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
05-02-2022, 11:04 AM | #17 | |
Rep 482
05-02-2022, 12:47 PM | #18 | |
Rep 1,373
The S58 has 2 small turbos which spool up faster The M340 has one big single variable turbo that has more lag. S58 puts out peak power from 3k RPM |
beden1512.00 |
05-02-2022, 12:56 PM | #19 |
Rep 4,206
05-02-2022, 02:00 PM | #21 | |
Rep 1,373
And yes im sure about the turbos. each turbo runs 3 cyls in the S58 The B58 has a twin power turbo which is much larger than one of the S58's |
05-02-2022, 04:19 PM | #22 | ||
Rep 148
The S58 has larger turbos than the S55. Yes maybe the B58 twin scroll single turbo it's a bit larger, but each Turbo has only 3 cylinders, so is not the same as to spooling one turbo with 6 cylinders. Quote:
B58 Peak torque at ~2000 rpm Peak Power at ~6000 rpm S58 Peak torque at 4300 rpm Peak Power at ~6800 rpm |
