05-10-2022, 08:06 PM | #1 |
Rep 314
M240 Stock Exhaust system
Hi all, I'm new to the performance car world. Came across the valved exhaust system concept Today. Just wondering if our m240 has this? Also, if I were to upgrade the stock exhaust, will this have an impact? TIA!
I doubt, therefore I might be.
05-10-2022, 08:29 PM | #2 |
Rep 200
Drives: 2022 BMW M240i
The M240i does have an active valve exhaust. It is on the right-hand side and opens/closes depending on your driving mode. Also depends on what you mean by upgrading your exhaust. If you change out the muffler in the back then yes cause the valve is after the muffler. If you just do a downpipe or midpipes then it doesn't affect the active valve exhaust.
05-10-2022, 11:51 PM | #3 | |
Rep 314
Brett_C_F30_G42381.00 |
05-13-2022, 08:08 AM | #4 |
Joint Chiefs of Staff
24207
Rep 190,807
I recommend you start with a catted downpipe, if you want more sound, switch to an axle-back or catback. You can still keep the valves with aftermarket exhausts
05-14-2022, 12:13 PM | #5 |
Rep 314
Agreed. I've been searching a good set of tips for the car but then I thought maybe I should just put on a new exhaust to have better looking tips and a better sound. I'm totally a newbee to this. Is there any good catback you'd recommend for 240? Welcome input from anyone. I'm sure I'm not alone here. TIA!
05-15-2022, 08:11 AM | #6 | |
24207
Rep 190,807
We should be seeing more released by mid summer
05-15-2022, 11:51 AM | #7 | ||
Rep 314
05-15-2022, 03:46 PM | #8 | |||
Rep 281
Exhaust systems apparently are not a direct fit and require some additional development work.
2022 G42 M240i xDrive TM/TR
Past: 2019 F32 430i MG, 2015 F30 328i AW |
05-15-2022, 04:53 PM | #9 | ||||
Rep 314
05-16-2022, 01:52 AM | #10 |
24207
Rep 190,807
No other way, unfortunately. You need GESI cats (active autowerke) or HJS (fabspeed) and both are pricey.
