BMW X5
      05-12-2022, 06:14 PM   #1
Royal1262
Royal1262's Avatar
Drives: 2022 BMW X5 45e
H&R wheel spacer defect
Just received my wheel spacers and one of them appears to have a machining issue. Should I keep or send them back?
      05-13-2022, 06:11 AM   #2
AECDY
Drives: BMW F15
Can't tell from the picture if it is just a different finish or if it is actually that they run the machine a bit more there and took off some more metal.
      05-13-2022, 12:10 PM   #3
Royal1262
Royal1262's Avatar
It's definitely a machining issue. I put the 2 together and there's a little gap where the imperfection is. Just wondering if anyone had some advice if it will cause me an issue if I install it. Being that it's not completely flat.
      05-13-2022, 03:20 PM   #4
DG-X5
Drives: 2022 F95 X5MC
Briefly thinking through the physics of it, I'd think it's a dicey proposition - you're looking for an even load force distribution and complete lateral support, and I dunno if you'll get it with this one anymore, at least in the long haul. Seeing as how you're about to mount this on a $75k-$125k ride, I'd suggest asking them directly once just to be safe? Worst case I'm sure that'll kick off the RMA process for you.
PHONE: (360) 738-8881
FOR NORTH AMERICAN TECHNICAL SUPPORT CONTACT: tech@hrsprings.com
FOR GLOBAL SALES AND TECHNICAL SUPPORT CONTACT: info@h-r.com
Royal1262110.50
      05-13-2022, 08:12 PM   #5
AECDY
Drives: BMW F15
I would not install. You want that part to be flat across. I would call their support line and get a replacement.
Royal1262110.50
      05-14-2022, 09:38 AM   #6
JaTe
BMW Junkie
JaTe's Avatar
Drives: X3, X7
If it's not flat, I would return it. The wheel needs to sit flush with it.
Current Stable: 2021 BMW X7 xdrive40i, 2020 BMW X3 xdrive30i, 2017 Toyota Tacoma TRD-OR
Retired BMWs: 1999 BMW 328i, 2005 BMW M3 ZCP
Royal1262110.50
      05-16-2022, 01:10 PM   #7
Royal1262
Royal1262's Avatar
Thanks, I've decided to return them. Don't want any issues after I install them and then can't return them.
DG-X5168.00
xbimmers
