      05-13-2022, 03:19 PM   #1
Karnidge
Karnidge's Avatar
128
Drives: 2020 Z4 M40i
2020 BMW Z4 M40i  [10.00]
Small tear in tire sidewall
I noticed this today when I was washing my car. A small tear in the tire sidewall. The tires are almost new, only 4K miles on them.
Not sure what to do. I imagine I should have this looked at before it causes a blowout. Has anyone run into this before? Is this repairable?
2020 Z4 M40i - Black Sapphire Metallic with Magma Red Vernasca Leather
      05-13-2022, 03:22 PM   #2
BMWILUVU
Drives: 340ix
That tire is done. Check the tire's warranty and replace that tire if possible by itself. That can't be fixed safely and I would not drive too aggressively until its fixed.
Karnidge128.00
Kilabyte4014.00
      05-13-2022, 03:34 PM   #3
FrankMstein
FrankMstein's Avatar
Drives: F80 M3, R56 Camden, F56
Warranty
      05-13-2022, 04:02 PM   #4
grannyknot
grannyknot's Avatar
1013
Drives: 2008 Z4M coupe
That looks like a flaw in the tire not tear from hitting something.
2008 E86 M coupe
      05-13-2022, 04:58 PM   #5
overcoil
Drives: M235i 6spd
I see 'bubble' often from pothole or curbing. What do you think ?
      05-13-2022, 05:29 PM   #6
440i6MT
Brother
440i6MT's Avatar
898
Drives: 2017 440i, soon E60 M5 Manual
I had a bigger tear and bubble on my car tire for thousands of miles, and I would toss the car around. Never an inkling of a problem.
Don't burn your own money.
Karnidge128.00
      05-13-2022, 05:52 PM   #7
Karnidge
Karnidge's Avatar
128
I'm paranoid now that I am going to get a flat. With no spare tire, it is something I want to avoid.
I heard that damage to the sidewall of a tire isn't repairable but I'm not sure if that's true.
      05-13-2022, 06:04 PM   #8
overcoil
Drives: M235i 6spd
No one who owns a business will repair that.
      05-13-2022, 06:23 PM   #9
NickyC
NickyC's Avatar
19587
Drives: M4 CS. Former G82, x2 F82, F80
EXTRA LOAD
      05-13-2022, 06:53 PM   #10
Mavus
Mavus's Avatar
2216
Drives: E90 335i, F80 zcp
the sidewall damage is usually not repairable. In your case it seems there is a bubble if you look above the tear. This tire may have internal damage. You should definitely dismount it and inspect it, and then decide if you want to replace it. It may be unsafe to continue using it.
      05-13-2022, 07:46 PM   #11
grannyknot
grannyknot's Avatar
1013
You can clearly see the bubble under that tear, as others have said, no one will fix that. See if you can call in your warranty, they are Michelin's so you certainly paid for that warranty.
2008 E86 M coupe
      05-13-2022, 08:25 PM   #12
GuidoK
#buildnotbought
GuidoK's Avatar
14670
Drives: Z4 3.0i ESS TS2+
replace.
the bump shows that tyre had a hit I think.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
      05-13-2022, 08:58 PM   #13
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
73583
Drives: ///M3-E92-DCT Silverstone II
Replace ASAP .
Remember Paul Walker ...
"MAX VERSTAPPEN" IS THE 2021+2022+2023+2024 F1 WORLD CHAMPION - #UnLeashTheLion -
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
DrFerry7430.50
mzwerner394.50
      05-14-2022, 09:27 AM   #14
Karnidge
Karnidge's Avatar
128
Thanks for all the feedback. I am having the tire replaced on Tuesday. Until then, she is resting in my garage.
M8Bimmer1459.50
br2wdc369.50
      05-14-2022, 10:00 AM   #15
Westside Guy
Westside Guy's Avatar
7621
Drives: 22 Z4 M40i, 21 228i Retired
Better safe than sorry, you are making the right move!
M8Bimmer1459.50
      05-16-2022, 08:02 AM   #16
FrankMstein
Originally Posted by nickyc View Post
extra load
extra load
extra load
      05-16-2022, 09:44 AM   #17
br2wdc
Drives: 2018 BMW M550i xDrive
I feel your pain, though mine was self inflicted: I clipped a median a little too close and didn't realize until a week later
Clearly mine was much worse then yours but same issue, I had to replace, but I was looking to replace all four anyhow so this just accelerated the decision.
2018 BMW M550i xDrive Mediterranean Blue
Previous: 2011 E90 M3 | LMB | DCT -- 2006 E90 330i | 6MT -- 2001 E39 540i | 6MT -- 1997 E36 M3 | Techno Violet | 5MT
