      05-13-2022, 04:08 PM   #1
Soylent
Soylent's Avatar
1244
Drives: 2025 M4C
Ceramic coat wheels- Does it work?
Interested to see what this has done for cleaning the brake dust off. Can you easily wash the wheels with a foam cannon and quick rinse? Or does it still require a lot of elbow grease?
2022 X3M Carbon Black Metallic
2021 M4 Competition Isle of Man Green
2019 M4 CP Austin Yellow-gone
2008 M5 Saphire Black-gone
2004 M3 Dinan S3 Jet Black-gone
      05-13-2022, 04:21 PM   #2
Rayien
Rayien's Avatar
Germany
586
Drives: '09 C4S,'22 M3CX
Even with a brake buster/pressure washer, there will still be residual brake dust. I say it requires "less" elbow grease and stays clean slightly longer.
F87 /// M2 Comp - Hockenheim Silver/Black/Blue Stitching
G80 /// M3 CompX - Imola Red/Black/Carbon Buckets
      05-13-2022, 09:20 PM   #3
Soylent
Soylent's Avatar
1244
Drives: 2025 M4C
Ok. Thanks
      05-13-2022, 09:31 PM   #4
aktif8
Drives: 24 Pure Blue M4 Vert
I've had great luck with Wipe New, believe it or not. It certainly doesn't repel dust, but makes it really easy to clean off. I'm a little leery of these wheels, since they're so intricate, but I have been contemplating it (no clue if it's ceramic, but it's something akin to it at the very least)
      05-13-2022, 10:24 PM   #5
bmw noob
bmw noob's Avatar
Drives: 2022 G80 Comp x-drive
Won't make the rinse only...but as was mentioned, using a wheel woolie and some soapy water is sufficient to clean instead of fighting the brake dust.
2022 G80 comp X-drive:San Marino Blue/ Silverstone, 826 bicolor, cf roof; exec pkg; shadow lasers; carbon pack; MSS HAS; spacers (15/12); Burger intakes; Unit17 front lip/CS Style spoiler; TLG flappies; full xpel ppf + 15% tint; AWE switchpath exhaust w/mid-pipes; csl strut brace; Eventuri cf engine cover
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335
      05-21-2022, 12:55 PM   #6
rm56well
rm56well's Avatar
Drives: G80 M3 comp
Definitely worth doing, I uses Gtechniq C5 works really well and lasts a long time, wheels beend burshing and wiping for cleaning but there is no sticky or stuck on dust, like above removes elbow grease requirement.
330e, awaiting delvery of G80 M3 comp
      05-21-2022, 07:56 PM   #7
Soylent
Soylent's Avatar
1244
Drives: 2025 M4C
Good info. I think I will try this. Remove the wheels to get at the barrels better and do the calipers too.
What Gyeon for the wheels? They have multiple products, Pure, Mohs etc.
      05-22-2022, 09:34 PM   #8
MVDsF30
MVDsF30's Avatar
Drives: 2018 530iX
I plan to ceramic coat my wheels and calipers. If I ceramic coat the barrels of the wheels if I need a tire replaced will the wheel weight stick or will I have to try and remove all the coating ?
      05-23-2022, 07:53 AM   #9
GregM4
GregM4's Avatar
Australia
1360
Drives: VERDE ERMES G82 M4 Xdrive
Gyeon have a product called Rim. I use this twice annually and find out really works well. I take the wheels of to do the barrels as well.
Current - G82 X-Drive in Verde Ermes
SOLD - F82 Sakhir Orange
SOLD - G01 X3 White
SOLD - E93 Burgundy
      05-30-2022, 06:41 PM   #10
luckylingy
luckylingy's Avatar
3380
Drives: X3M
+1 on benefit of ceramic coating rims, both for cleaning and drying. P&S Brake Buster gets most of the brake dust without agitation (okay for 'light days' when I'm pressed for time), but otherwise I still undergo my wheel/tire brush regimen to lightly agitate the cleaner. I also use a leaf blower to expel 90% of the water during the drying step. Results are consistently great.
      06-03-2022, 12:05 AM   #11
Indo Rider
Drives: 135
I had this same question recently when getting wheels coated. I was told by what I believe to be a pretty reputable shop that does a lot of high end cars that this isn't an issue. So I went for having the barrels coated. We'll see I guess.
      06-07-2022, 06:30 PM   #12
Lotus07
Australia
29
Drives: F80M3 - sold 24th June 2022
When you remove the wheels for cleaning/Ceramic coating what torque should applied to refit the wheels?
      06-08-2022, 08:44 PM   #13
forcefed
forcefed's Avatar
Drives: .
101
      06-13-2022, 06:05 AM   #14
LivinLrge
LivinLrge's Avatar
Drives: M4 Competition
2021 BMW M4 Comp  [0.00]
2011 335is  [9.83]
I had it professionally installed..$600.
Is it worth it? Eh, it makes it easier but it's not rinse off like the shop told me it would be.
I use Sonax on the wheels to get the brake dust off then wipe with a cloth to remove any excess.
Imo Sonax is the workhorse here along with my elbow grease. I would make the argument that $600 of Sonax may outweigh the benefits of the ceramic coat.
2011 335IS - Alpine White/Coral Red
2021 M4 Comp - Alpine White/Fiona Red
      06-24-2022, 08:24 PM   #15
Soylent
Soylent's Avatar
1244
Drives: 2025 M4C
Thanks. This will be my first job once the lift is installed.
      07-07-2022, 03:34 PM   #16
The Nerd
The Nerd's Avatar
447
Drives: 22 M3 Comp xDrive
I'm surprised there isn't more talk about replacing the pads for a few hundred $$. If you don't track your car…..what's the disadvantage to having aftermarket low dust pads put on?
