06-12-2022, 12:28 PM | #1 |
Rep 120
How to replace start/stop button
ÒMG, i was here try to take off old button in 2 hours, it doesnt work. And start wonder can i replace button on this model (230i 2022) this way ???
06-12-2022, 02:19 PM | #2 |
Rep 428
https://g42.bimmerpost.com/forums/sh....php?t=1886541
Absolutely. I only used one but it worked perfectly. Link to the thread above.
'22 M240i BSM, Shadowline, Black 791M wheels, Red Calipers, ///M Carbon Front Lip, ///M Carbon Spoiler, ///MCarbon Door Sills, Milltek Catback w/Black Tips, Dinan Carbon Intake/Engine Cover, AA Catted DP, Dalher Valve Controller, OEM+ Strut Bar, Red Start/Stop, Floating center caps, TLG Mud Flaps, Black Badges, Led Projectors, 50th Emblems, Carbon Diffuser/Mirrors w/smoke signals/Side Wings/Cooling Shroud/KIES fire extinguisher, Yellow DRL
06-12-2022, 02:24 PM | #3 | |
Rep 120
06-12-2022, 02:33 PM | #4 |
Rep 428
Straight up, and quickly. So grab and pull up hard and fast. Not a slow pull
06-12-2022, 02:52 PM | #6 |
Rep 428
Just have to send it. No hesitation. Maybe just try one glue stick centered?
06-12-2022, 04:12 PM | #7 |
Rep 326
I used the sticky gunk that came with the new button. I kneaded it into a ball and spread it out over the entire surface of the old button. Then I used the round, plastic case the new button came in, and pressed it into the sticky material firmly and pulled up quickly. It worked. I think the trick may be having the force evenly distributed over the button.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also" |
06-12-2022, 06:49 PM | #8 |
Rep 120
06-12-2022, 08:32 PM | #10 |
Rep 52
I couldn't get mine out with the glue sticks either. I ended up picking up some duct compound and was finally able to get it out with that. It's really sticky stuff. Wear gloves.
One of the clips on the OEM button did break, though. |
Brett_C_F30_G42383.00 |
06-12-2022, 09:04 PM | #11 |
Rep 86
No damage within the module itself in the car though right?
06-13-2022, 10:43 AM | #13 |
Rep 120
Still impossible, a glue stick adhesive is strong like i can grap button and pull out by my hand, but glue stick brokken before button came out. I "feel" like pull straight up is a wrong way, it can't be that strong
06-14-2022, 09:20 AM | #14 |
Rep 1,104
Buy this
Poweka 13FT Butyl Rubber Sealant Tape for Car Auto Headlamps Window Door Windshield,4M Black Butyl Rope https://a.co/d/dk6Boi6 This is what I did and it worked great! |
06-14-2022, 11:52 AM | #15 |
Rep 42
I used 7 of the small glue sticks. It covered the whole button. I think pulling on the edges spread it a little to pull out. 3 in the middle did not work for me.
xcelir8bmw413.00 |
09-26-2022, 07:17 PM | #17 |
Rep 2,070
Did any of you guys have an issue where the aftermarket button was not perfectly centered? I installed mine and the gap was larger on one side and it drove me crazy so I went back to stock. I had this issue with 2 buttons I've tried.
The stock button fits perfect, but its boring |
Giovany_2410.50 |
10-15-2022, 11:57 PM | #18 |
Rep 2,070
Ended up buying this one (my 3rd button) and it fits and looks perfect.
Same exact print spacing and font as OEM. It just does not light up the same as the rest of the controls, which I'm ok with. Lanyun replacement for bmw engine... https://www.amazon.com/dp/B09P1J1HGY...p_mob_ap_share |
10-16-2022, 05:55 PM | #20 | |
Rep 2,070
I waxed it last night which made it a bit glossier. https://g42.bimmerpost.com/forums/sh....php?t=1890468 |
Vudumonkey25622.50 Coconut797.50 |
04-03-2023, 05:44 PM | #22 | |
Rep 484
Drives: 2022 BMW M240i
