2009 e93 335i FBO $13,500 obo
06-12-2022, 03:35 PM | #1 |
Rep 603
-2009 e93 335i with 102k miles....sports package...comfort access....heated steering wheel -6 spd automatic with paddle shift -Space gray with Dakota gray interior -index 12 injectors -upgraded PCV valve (1st mod done ~ 79k miles) -new Rotors and pads @ 100k miles -turbos replaced @ ~ 55k miles by BMW of Winterpark, FL -mickey mouse fitting replaced @ 85k miles (preemptively) (thermostat to block fitting) -coolant reservoir and all hoses replaced @ 85k miles (preemptively) -OFHG and oil cooler gaskets done @ 85k miles (preemptively) -fresh plugs and coils along with oil change (liqui-moly used since I've owned it) -waterpump and thermostat replaced @100k miles -Alternator Voltage Regulator replaced @ 85k miles (preemptively) -M3 front control arms installed @ 85k miles -battery replaced 2020 -9in Eonon headunit with back up camera -SSR DCA's -Wagner 5 in stepped IC -ARM CP with genuine TIAL bov -ARM catless DP's -MHD stage 2+ tune -Xhp stage 3 transmission flash -LUX H8 189 Halo bulbs -smoked LED side markers -clean title in hand. -ZERO oil leaks It's time for me to move on from my e93. I've owned it for 3 years now, found it in Florida and brought it to Indiana. It's never seen the snow or salt. I park it for the winters, it's been a summer only car for me. The vast majority of the known weak points have been addressed. She runs perfectly, leaks zero oil. Oil has been changed every 8k miles with liqui-moly and the plugs and coils changed every 10k miles since I've owned it. FCP is my friend. Top operates smoothly and I oil ALL hinges and moisturize all seals every spring and fall. I've posted it on TRED and FB Marketplace. It needs nothing, all of the heavy lifting has been done! PM with any questions. Car is located in southern Indiana. https://www.tred.com/buy/bmw/3-serie...WL73599P181229 Thanks for looking! Last edited by fgpalmer71; 06-24-2022 at 10:28 PM.. |
