leaking from the radiator upper driver side(left side)
06-14-2022, 02:24 PM | #1 |
Rep 7
Hi guys i have 2008 e90 that have a huge coolant leak
i thought it was the hose above the radiator and replaced as it was cracked but now i see it leaking from the radiator upper driver side. how can i know if the radiator is bad or if there is anything else causing the issue am trying to work on my own car and still learning so anything you know will be so helpful Here is a picture I took earlier today thank you so much |
06-14-2022, 04:07 PM | #3 |
Rep 7
Do you know if anyway to replace that part or the whole radiator need to be replaced
And if so is it worth looking for an upgraded radiator or just stick with the oem Thank you |
06-14-2022, 05:24 PM | #5 | |
Rep 7
06-14-2022, 09:47 PM | #6 | |
Rep 2,529
Drives: 2011 328i Wagon
OP - just buy a Nissens radiator - it will almost certainly last longer than you will own this car, and work just fine, for less than $150 at the usual online parts suspects.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
06-15-2022, 11:19 PM | #7 | ||
Rep 7
06-15-2022, 11:36 PM | #8 |
Rep 3,051
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Nissens and Mahle-Behr are both good ones. I used Nissens my last go around.
bhashe0.00 |
06-15-2022, 11:42 PM | #9 | |
Rep 7
06-16-2022, 08:16 AM | #10 |
Rep 3,559
Behr rads had issues. Many people, including myself, had to replace the new Behr rads within a year. Mine actually failed within 9 months.
Few shops in my area even stopped sourcing them because of all the warranty claims they had to do. Speaking with one mechanic, it seems that there was a bad production batch in 2020. He mentioned he's had 10 of them come back within a year. I got a Nissenss from Rockauto and it's been good so far. We will see what happens when winter comes. Make sure you get the correct variant for automatic transmission vs manual. Last edited by Wolf 335; 06-16-2022 at 08:22 AM.. |
Mike K325.00 StradaRedlands4997.00 |
