06-18-2022, 11:33 AM | #1 |
![]() 137
Rep 141
My order regrets - don't make the same mistake I did
I placed the order for my m240i last December. It arrived in April, and I love the car. Well worth the wait and various delays - I was originally quoted Feb arrival, then march, then April 1st, I was driving her home.
However, with that being said, if I could it all again, I would change these 3 things. 1) I would have checked the box for the HK radio. My client advisor told me I couldn't order even though it showed you could. From what I understand, that was incorrect, and I could have spec'd it with it. BMW would have deleted it for me if it wasn't going to be available. Choose that option! 2) I would have went with the "cooling and high performance tire package". From what I understand, this actually comes with larger brakes and the brakes are my least favorite part of the car - they are fine but I like my brakes to be more aggressive. 3) I would have chosen the cogac over the tacora red. This is just personal preference. While the tacora red is a great interior, I could have been happier with the cognac and the cost savings. The rest of the car is absolutely fantastic. I feel this car punches well above its weight/cost. I couldn't be happier to have this as my daily driver. |
06-18-2022, 12:31 PM | #4 |
![]() ![]() ![]() 2090
Rep 515
I miss the days of replaceable sound systems. Even in my former 2011 Mustang and 2015 Challenger, I was able to replace the speakers, add subs and amplifiers / equalizers etc. Granted, head units were too far integrated to mess with
I wouldn't mess with even tapping the speaker wire in these for gear of throwing a code. I have the HK in my order so hoping it is as good as what I have now in my G70 or the B&O in my A5 but from what I've read it will be inferior |
06-18-2022, 12:46 PM | #5 |
![]() ![]() ![]() ![]() ![]() 755
Rep 706
g42m240
I also was critical of the brakes when i first got the car. Now they seem "normal", perhaps i got used to em or they needed break in. I did do some aggressive breaking to really heat them up and they seem better. Also i believe the actual braking performance relative to stopping distance is on par with other cars of this weight. I think it is more a matter of brake feel and pedal travel with this car. Different pads could give a more aggressive initial bite that i felt was lacking. But frankly i have full confidence in these standard non-performance brakes and did do a track day with em. You can explore upgrades to the sound system, i think there are some bimmertech links that do address upgrading from your current stock system with plug and play components. I'm sure some folks have done it, and some have upgraded from the HK system as well, definitely a DIYer. Interior: i did get the cognac and love it...sorry. |
eddj490.50 |
06-18-2022, 03:09 PM | #6 | |
![]() ![]() 194
Rep 303
Drives: 23 G80 Yellow
If you do get the HK system then get Bimmercode and code in the Sound Profiles. You can mess around with the equalizer too to dial things in a bit more. |
06-18-2022, 04:05 PM | #7 |
![]() 137
Rep 141
06-20-2022, 08:58 AM | #8 |
![]() ![]() 2065
Rep 1,913
Built my 230i with the big brakes but bought a car off the lot with the standard brakes.
Standard brakes are just fine based on my experience. Unless one road course tracks the car and bigger brakes might better deal with the extra heat at all other times bigger brakes just add unsprung weight. |
06-20-2022, 09:29 AM | #9 |
![]() 220
Rep 251
I sat in an 330i that had the PB/cognac combo and I really liked it, but, I ended up going w/ the black/blue contrast vernasca. Wish we got the m-style seatbelts as well...
I held off on the ZTK package because I don't plan on tracking this car, though I wonder if it'd be worth it to go with a sensatec seat and add the ZTK, if for nothing else, the PS4S's from the factory? I've not had good experiences with Pirelli tires in the past. |
06-20-2022, 09:42 AM | #10 | |
![]() ![]() 44
Rep 55
For me, the 893M wheels were enough to check the box for the ZTK pack. It really changes the car's stance. The Michelin PS4S tires are a big bonus. I'm not fond of Pirellis either. I had PZero run flats on my 435i. They were definitely a softer compound and did not wear very well. Last edited by MillieMiglia; 06-20-2022 at 09:56 AM.. |
Jonesymx29219.50 |
06-20-2022, 03:25 PM | #12 |
Rep 14
06-22-2022, 11:10 AM | #13 | |
![]() 90
Rep 87
And you don’t have to be an audiophile to realize the standard system in the 2 series is NOT “fine”. |
06-22-2022, 11:14 AM | #14 | |
![]() ![]() 44
Rep 55
For those interested, here's a you tuber reviewing the HK system in the M240i. |
yanks1485.00 |
06-23-2022, 07:57 AM | #15 | |
![]() 137
Rep 141
I had to tell them how to add the adaptive cruise (thanks to this forum). I should have forced their hand to select HK. |
06-23-2022, 01:57 PM | #16 |
![]() ![]() 217
Rep 155
I had the stock system of my F22 M240 upgraded to BavSound, and I can concur that it's a huge improvement.
I have the HK system on my G42, and I was pretty unimpressed out of the gate. After fiddling with the equalizer though, I find it to be actually pretty terrific. It's strange... I typically use flat equalization as I'd just as soon listen to the music as the artist intended (without boosting or reducing elements of the music), but a good smiley face curve does wonders to increase depth in this car. |
