n54 blown head gasket?
06-21-2022, 08:55 PM | #1 |
Rep 15
so i got a new water pump/therm, hpfp, remanded injectors, inlets, catless downpipes w custom 3.5 inch exhaust, pcv valve "upgraded", oil catch can, new coil/plugs, walnut blast, new oil filter housing gaskets and yet i still have smoke coming out the exhaust only sometime i haven't actually driven the car in months but last time i did it overheated and i had to get a tow but it was the coolant overheating and not the oil. so after problem shooting my ltfts being high and trying to do "maintenance" I never got it 100% and I've concluded that i have a blown head gasket via a combustion leak detector and i believe the cause of my ltft being +20s is the coolant in the cylinders but before i pull the motor what I cant under stand is sometime when i start it it doesn't smoke at all and other times it does I'm so confused on what to do the codes i currently have are
2E83 electric coolant pump power reduced operation. 2EFE electric fan, activation "have my fan out for easy of access" 2E9F oil condition sensor https://datazap.me/u/thebigbag/help?log=0&data=3-18 data log of a start to idle engine was a little warm. any help would be appreciated |
