DMTL Problems? EVAP? 2008 E92
06-23-2022, 09:27 AM | #1 |
Rep 58
Looking for some help. I have a CEL.
Changed purge valve and gas cap. Only the SEL light went away. It is still running DMTL codes. Changed the DMTL and CEL went away but came back after driving ~5 miles. Also have code for low pressure with turbos. Anyone can help? Attached is a photo of the codes. 2A13 2A18 30FF |
06-23-2022, 12:01 PM | #2 |
Rep 1,682
Could be a leak detection pump failure. If your car is a PZEV sold and registered in California, at 111K miles those should still be covered under the 15-year 150K mile CARB PZEV emissions warranty.
This video has different error codes, but this is the DMTL pump. Yours may also be related to the control circuit if it could not activate the pump. |
beems581.50 |
06-23-2022, 12:05 PM | #3 |
Rep 58
06-23-2022, 12:13 PM | #4 |
Rep 1,682
Call your local dealer, if they are clueless then try BMW's 1-800 number. Also refer to the warranty booklet.
See page 44 of the 2008 3-series warranty booklet on PZEV warranty: https://www.bmwusa.com/content/dam/b...nformation.pdf Manufacturers Warranty Coverage: – For 15 years or 150,000 miles whichever occurs first: 1. If your vehicle fails a Smog Check inspection, all necessary repairs and adjustments will be made by BMW NA to ensure that your vehicle passes the inspection. This is your emission control system PERFORMANCE WARRANTY. 2. If any emission-related part on your vehicle is defective, the part will be repaired or replaced by BMW NA. This is your emission control system DEFECTS WARRANTY. |
06-23-2022, 12:25 PM | #5 | |
Rep 58
