Sounds kinda like an exhaust leak in the engine bay, but not sure
06-25-2022, 12:54 PM | #1 |
Rep 22
Hey guys, I am new to the forum and the BMW platform as well. I picked up a 2007 335i e90. It has a sound like air is escaping from around the valve cover gasket. I am on a group on FB and posted a vid there and one of the guys in the group said it sounds like my hpfp is on the way out. I have been having long cranks (about 5 to 6) and a loud pop then it starts up. I also have the smell of gas from just putting the key fob in the socket and not even trying to start the car up. There are 4 index 12 injectors and the other two are index 9 and 2. Don't ask me why. I pulled the coils out and cylinder 1 is dry but the other 5 have oil in them. The PO said he replaced the valve cover gasket and the oil cooler gasket. If I can figure out how to post the vid on here I will. Been a long time since I have been on a forum so I forgot how to do the vid upload. The car has not been maintained well at all. So I know I have a lot of work ahead of me. I ordered the injector tool kit and a new oil pan gasket with hardware because the PO said the the belt shredded and it put a gash in the front main seal. IDK if he was lying about a gash because from what I have read the seal is usually done for if the belt ever shreds. I have also ordered hpfp and the water pump because he said it went out and he had to limp it home. If anyone can help point me in the right direction with uploading the vid because I know that will help more than my trying to explain it would be helpful. Thanks in advance.
06-25-2022, 01:31 PM | #2 | |
Rep 1,893
1) There is very little in what you describe that sounds like a bad HPFP and if so, you just dropped $550-800 for no reason. To be sure, index 9 injectors were probably the most fragile and unreliable release - would not be surprised if you had injector issues. Let the car sit overnight, pull the plugs in the morning and look/smell for wetness/signs of gasoline 2) Oil on the sparkplugs? I'll assume you mean there was oil in the sparkplug well. Either the oil is left over from before the gasket fail or the previous owned fucked up the new gasket install or the valve cover itself is cracked so the problem wasn't the gasket in the first place. In any case, irrelevent to your driveability issue 3) And the waterpump? You're replacing it on spec without having even read any error codes? Another $350-500 for potentially no reason. Yes, they fail with some frequency but some due diligence is in order. Unless money and time is no issue for you. 4) You bought an oil pan gasket because you think a shredded belt may have damaged the front seal? First, you don't need to replace the oil pan gasket to replace the seal. Second, is there actually any visible damage to the seal or are you just going by what the previous owner told you? You said it yourself - the car has not been maintained well at all - so don't trust anything the previous owners says or says he did. Start at the beginning and make no assumptions. And read/report the codes |
06-25-2022, 03:01 PM | #3 | |
Rep 22
Sorry forgot to add that I ordered a obd dongle and have bimmerlink and bimmercode already on my phone. Dongle will be here Monday so I will have codes after I get off work. The only reason I bought those was because the guys in the FB group I am in said that those should be replaced. PO said that water pump did go out and was one of the reasons he wanted to get rid of it besides being in college and not having money to throw at it anymore. Yes there is oil in the spark plug wells as well as in the valley (I guess is what it is called where the injectors are). Can water or gas get in the plug wells? The last three cylinders have what looks to be water and oil mixed. Thanks for the reply! |
06-25-2022, 03:19 PM | #4 | |
Rep 1,893
As for the guys in the FB group or posters in E90 or anywhere else, you would be wise to take everything anyone says, including me, with a big grain of salt. Opinions are easy; they have to be justified with logic AND with data. Gas cannot get into the spark plug wells, unless the high pressure rail is leaking perhaps from a hard line fitting. I've seen it happen, I don't think it's common. Water (rain) could get in if someone left the soundproofing cover off or some very unusual crack might let coolant out. Again not common, but pretty easy to distinguish coolant from water. I'll say it one more time - forget what the original owner said, it's more than clear he had no idea how to diagnose or maintain his vehicle. Find out what the issues are yourself. Start by cleaning the fuck out of everything - all oil, grease, coolant, gas. Then run the engine and see for yourself if, when or where any liquids are accumulating. Last edited by dpaul; 06-26-2022 at 06:54 AM.. |
06-25-2022, 03:28 PM | #5 | ||
Rep 22
06-25-2022, 03:31 PM | #6 | |||
Rep 22
06-25-2022, 09:08 PM | #7 |
Rep 1,893
06-26-2022, 09:38 AM | #9 |
Rep 22
Well it did end up eating the seal. Pulled the pulley and these pieces of the belt was in the seal area. He put this new belt on and it is eating the outside of the belt. Is there a cause of this?
06-27-2022, 08:17 AM | #10 |
Rep 400
Drives: 2011 e91 328i RWD
Oil filter housing gasket and valve cover gaskets will surely need changing if your main seal is still ok?
06-27-2022, 08:30 AM | #11 | |
Rep 1,893
And/or the power steering pulley contacts the subframe because the engine mounts are worn. Inspect power steering pulley and subframe in possible area of contact And/or the OFHG leaks, oil gets on the belt, belt degrades, chaos ensues. You are likely already aware but if not, the big worry is that some of the belt shreds have entered the crankcase and will plug the oil pickup. Oh joy. EDIT: oh yeah, could also be belt tensioner, AC compressor pulley. Probably more. Last edited by dpaul; 06-27-2022 at 08:35 AM.. |
StradaRedlands4998.50 |
06-27-2022, 08:41 AM | #12 | ||||
Rep 22
I will look at today when I get off work. I'm guessing if the motor mounts are worn the engine will shake like any other motor? I inspected the crank before inserting the seal. Didn't see any pieces of belt in there so hoping for the best that there is not any in the pan but I'm feeling doubtful. My OBD single will be in today so I will know more after that codes wise. |
06-27-2022, 06:01 PM | #13 | |||||
Rep 22
06-27-2022, 06:18 PM | #14 |
Rep 3,053
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
06-27-2022, 06:21 PM | #15 | |
Rep 22
06-27-2022, 06:26 PM | #16 |
Rep 1,893
06-27-2022, 06:27 PM | #17 |
Rep 3,053
06-27-2022, 06:27 PM | #18 | |||
Rep 22
06-27-2022, 07:13 PM | #19 | |||||||
Rep 22
A lot better. Cylinder 6 is where the sound like air is escaping is coming from. |
06-28-2022, 05:05 AM | #20 |
Rep 71
06-28-2022, 06:11 AM | #21 | |
Rep 1,893
2e83 (waterpump) and 2e97 (alternator) could be related. Both devices (along with oil condition sensor and IBS) communicate on the BSD (bit serial device) bus where a defect in one device can interfere with communication of another. Although there are no current explicit BSD codes, there were earlier - 2e84 (wp) and 2e8E (IBS) and the correspondance of alternator and wp errors is highly suggestive. Easy enough to explore the alternator issue - get the freeze frame data and see what the system voltage was when the fault was set.. Or for that matter, just measure the system voltage yourself at the jumper terminal with the ignition on but engine off, then with the engine running. 2eDB often follows from an alternator issue signifying low or fluctuating system voltage. However, it could be due to a variety of other causes, most typically the battery or battery contacts. It can also mean an excessive current is being drawn after ignition shut off i.e. fan motor stays on because waterpump isn't up to speed. So you get the idea how interconnected all these things can be? Again, check freeze frame. 2EFE is not the fan code I expect in conjunction with a wp problem - it indicates low voltage at the fan motor which could be a dead motor, bad fuse, bad connector etc. (BTW you cannot test the fan by just putting 12v across it - do not do that). It's not so easy to fit with the other codes but again, easy enough to explore, a) check freeze frame for system voltage at time of fault b) put a DVM on the big heavy wires (red, black) in the fan motor connector with engine running. A real curiousity here is that you don't report any sign of overheating. If your wp was bad OR your fan was bad you would overheat. All that said, my SWAG, as gbalthrop would say, is that 2A9A is the significant code in terms of your starting issues and possibly this "air escaping" noise (which I suspect has nothing to do with air escaping). The explanation could be camshaft position sensor, a timing chain tensioner issue, a vanos solenoid. Those are cheap enough I'd just replace them all but you could of course explore them sequentially. Oh yeah, and fill your gas tank. |
06-28-2022, 07:05 AM | #22 | ||||
Rep 22
The battery is brand new. The one that was in there was dead. I registered the new one via BimmerLink I think the fan thing is because it's not in the car at the moment because I did the crank seal and haven't put it in because I was gonna do the water pump but may hold off on that because it sounds like that may not be a problem. I have been reading about the vanos issues related to the code. Also when I clean them to see if that helps I need the o rings right? Yeah I will get some gas for it today. I don't wanna drive it because of the water pump. I started it yesterday after I re ran the codes and noticed some smoke coming from exhaust and a pop sound under the car when blimp the gas for a second or two. I'm kinda thinking turbos are shot. Not sure though |
