      06-28-2022, 10:44 AM   #1
ScaldedDog
ScaldedDog's Avatar
368
Drives: 2022 X5 45e
Ceramic coating wheel barrels? Brake calipers?
We just had our new 45e PPF'd and ceramic coated, but they did a "wheels on" job, and so only coated the outer part of the wheel, and what they could reach on the 740Ms. They offered to do the barrels for $200, but that seems like a lot just to remove the wheels, which is the lion's share of the work. I'm thinking I'll do it myself.
My question is, does coating the barrels make them easier to clean, and do they actually get clean? In other words, is it worth it?
On a related note, is it possible, and wise, to coat the fancy blue calipers on this thing? I never see anything about doing that, but I'd like to be able to keep them looking good, if possible.
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver
2017 JKU Sahara - Beach jeep
1988 4Runner on 40's - Off-road trailer queen
2001 PSD Excursion - The slave that drags the queen
      06-28-2022, 11:24 AM   #2
1Mors
1Mors's Avatar
Drives: 2022 X5 xdrive40i msport
I have to say HELL yes ceramic coating on wheels blocks just about everything including break dust. Then you can use products like wheel cleaner from Gyeon to easily clean everything on the wheels. I have Gyeon RIM coating. Amazing so far..
White3401565.50
      06-28-2022, 11:49 AM   #3
ScaldedDog
ScaldedDog's Avatar
368
Drives: 2022 X5 45e
Thanks!! I may be sold. Did you coat your calipers?
      06-28-2022, 05:53 PM   #4
1Mors
1Mors's Avatar
Sorry traveling absolutely coated my blue calipers
      06-28-2022, 06:02 PM   #5
Mo2002
Mo2002's Avatar
233
Drives: 2021 X5M
I think it's worth it. I had my barrels, wheels and calipers coated. Just note that some coatings on wheels and calipers may not last as long due to the heat. I know Modesta makes a coating specifically for high heat items.
      06-28-2022, 06:43 PM   #6
malvern_man
United Kingdom
626
Drives: X5 40i xDrive
Just had my X5 40i PPF'd and ceramic coated. I had a wheels off ceramic coating applied to the faces, barrels and calipers, Gyeon products were used.
Below is the actual work undertaken...
Remove All Wheels, Remove Ferrous/Iron/Organic Fallout Removal, Polish Wheel Surfaces, Alcohol Wipe And Install Double-Layer Ceramic Q² RIM. Steam Clean Callipers And Install Double-Layer Si02 Q² RIM. Steam Clean Wheel Arch Liners And Install Single-Layer Si02 Q² TRIM.
      06-28-2022, 08:20 PM   #7
chefwong
Drives: X5
Scalded -
$200 seems fair IMO.
Look at it this way. $70 is the entry fee for a coating you buy yourself. Once you crack that bottle open and use whatever you use, whatever is left over has a shelf life of *up* to a year. YMMV on the shelf life, but the clock starts ticking once the bottle is open.
Another option, does last as long but different way of spending the green, is to use a touches sealant, which you would just apply when worn, and it does get in every *nook and cranny* due to the nature of it.
I don't like the touchless since it get's on the rubber...and you can't control that if you're the type to dress your tires every now and then..the tires end up getting the sealant on them if you go that route.
      06-28-2022, 11:05 PM   #8
ScaldedDog
ScaldedDog's Avatar
368
Drives: 2022 X5 45e
Nice car!! How many miles did you have on it before you had the wheels done? We've only got 200, so I'm thinking my cleaning process could be a little less involved. Perhaps not.
Originally Posted by chefwong View Post
Scalded -
I don't think $200 is bad, but I have a lift so it's a trivial exercise to remove all four wheels, prep, treat and remount them, and get the car back on the ground. The key in all that is the prep, but I doubt the place I'm using is going to do all of what malvern_man had done for $200. I could be wrong, though. I do know the stuff they used on his is $50 on Amazon.
      06-29-2022, 05:45 AM   #9
malvern_man
United Kingdom
626
The car is brand new, it had done 66 miles when I took it in to my local detailers. The wheels were part of the whole package that I had done.
      06-29-2022, 07:10 AM   #10
chefwong
Drives: X5
Scalded - My original reply was just to point out that there was a finite shelf life on a coating bottle, once you open it up if you were not aware.
Spray sealants are a easy option as well and will get every nook and cranny and may offer you better ROI since calipers won't last as long so you can re-up more often. Great if you're the type to not do tire dressing of any sort. I would skip this type of app if you do as the spray sealant will also overspray on the tires
      06-29-2022, 11:49 AM   #11
ScaldedDog
ScaldedDog's Avatar
368
Drives: 2022 X5 45e
I'll probably use the remaining amount on my tow rig wheels. It's a 20+ year old truck, and not really worthy of ceramic coating, but the EBC brake pads I use on it make a mess of the wheels in a hurry. If I could make them easier to clean, and do the same for our X5 wheels for $50, I'd call that a win.
nZtiZia5624.00
      06-29-2022, 06:19 PM   #12
chefwong
Drives: X5
Scalded -
If you are not familiar with the rinse sealants, this is something you may want to entertain to use on the wheels since you can use it on your PPF. You and Malvern are going to hate this comment....but nothing really stays for long ontop of PPF, so it's a good idea to seal/topcoat/recoat the PPF every now and then anyhow. Whether it be a touchless rinse spray or traditional spray sealant..on your PPF install.
      06-29-2022, 06:39 PM   #13
malvern_man
United Kingdom
626
Scalded -
Spray on rinse off sealants are as you say only meant to be used as a topper to your ceramic coating, in general they only last a few months. They can though be used as a standalone product on non coated cars. Even if I've used a spray on rinse off product I sometimes go over the top of that with a quick detailer either a ceramic one or a normal one. My favourite at the moment is SOFT99 Fukupika Spray Advance Strong Type, you only need a couple of spritzes per panel then spread with a microfibre cloth, no buffing required.
      06-29-2022, 06:45 PM   #14
chefwong
Drives: X5
MM -
Just a opinion....but PPF is plastic...ceramic coating is nice but it doesn't last nowhere as long on PPF than it would on traditional paint. I didn't want to say it outright since you both -paid- for coating onto of PPF, but coating ontop of PPF is just flushing money down the drain. A $10 spray wax will net the same results given the "medium" it is being applied to. Just ones opinion though
      06-30-2022, 01:47 PM   #15
malvern_man
United Kingdom
626
MM -
PPF cannot be ceramic coated in the traditional manner as in a bottle of coating and an applicator pad. Gyeon PPF is ceramic coated during the manufacturing process, the only parts of my X5 that have been ceramic coated in the traditional manner are the parts that haven't been PPF'd. I hope this clears up any confusion.
Parts PPF'd....front bumper, wings, bonnet, headlights, sills (rockers) door pillars and mirror casings. Everything else has been ceramic coated including the wheels, interior etc.
      06-30-2022, 02:27 PM   #16
chefwong
Drives: X5
All good MM. Just bringing the topic for discussion as many shops offer coating ontop of PPF. Yes, there is a handful of supposedly PPF specific coatings out there but IMO, nothing lasts.....and a $10 spray wax is just the same topper on PPF. Not familiar with Gyeon PPF however. Has it been out long enough with a decent track record on how it looks after 2-3-4, etc.
If you have ever removed old film off a car, which kinda gets masked just due to it being on paint....sometimes you may be surprised how not optically clear it will be when not maintained..
The coating as a additional service onto of the PPF is just good revenue for the installer but poor ROI for the recipient ..
      07-12-2022, 07:00 AM   #17
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
Another vote for full coating on wheels and calipers if this will be a car you spend a lot of time cleaning. The "cheap wheels" 19" clean easily without coating.
      07-12-2022, 07:35 AM   #18
White340
Drives: 2018 M3 Comp / 2022 X5 45e
Did you ppf the whole car? I'm being quoted 6500 for a full Xpel ppf. With this package ceramic on top is 500 more down from 1000.
Or 2500 for full front, 600 for rocker panels and 600 rear bumper.
Wondering if the doors, roof and trunk are worth the extra 2800.
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO
2016 340i xDrive : AW/CR (sold)
      07-12-2022, 07:41 AM   #19
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
though I'm no expert, I question the validity of this statement. prior to ceramic-infused ppf, there are ceramic coatings developed and designed to be applied onto ppf via applicator pad (my detailer made a video during my installation), and it very clearly works as intended with excellent hydrophobicity. I don't know exactly which ceramic product he used on my XPEL stealth ppf but most if not all displayed products in the showroom are Gyeon. i recently refreshed with a top coat of Gyeon Q2M Cure Matte sealant, and water continues to bead and sheet off super slickly. here's a video showing the hydrophobic performance of non-coated stealth ppf:
i can tell you that water beads and sheets off my ceramic-coated ppf a lot better than shown in the video
      07-13-2022, 11:46 AM   #20
chefwong
Drives: X5
nztizia -
While there are a handful of PPF specific coatings out there, just curious. Have you benchmarked how long it has lasted before you see it fade/falling off. IMO nothing really lasts for long on PPF (with no known benchmark on the specific PPF coatings) we are now discussing
      07-13-2022, 01:51 PM   #21
medphysdave
My car was 7500 for paint correction, full ppf, and ceramic. This is ppf from template. I think the quotes for the x5 are in line.
I'm likely only doing the front bumper or full front on the next x5. Reason being is that in 17k miles the one we just traded in doesn't have any rocker damage, or side damage to speak of. Nothing on the hood either. I'll probably add a piece on the roof to protect the window roof interface.
      07-13-2022, 03:20 PM   #22
chefwong
Drives: X5
It's a slippery slope. I'd consider the rockers as well as bare minimum. But it depends on how one's eyes interpret paint .....
I started with a plan of full front, rockers, Door Pillars (the black on B pillars fade and need polishing and sealing *alot* to keep it looking good). I wanted the rear bumpers. After tallying the list, I said F'it. Just wrap the whole thing...
