Replacing parts, drive cycle?
06-29-2022, 09:15 AM | #1 |
Rep 58
Anyone know after replacing parts, how long does it take to complete a drive cycle? I replaced some parts but CEL still comes on.
E92 335i |
06-29-2022, 10:08 AM | #2 |
Rep 1,023
There is no set distance/duration. It requires going through the various portions of the drive cycle.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
The Nightman1091.50 |
06-29-2022, 10:12 AM | #3 |
Rep 3,060
One of life’s mysteries, I went through this when I owned an E46 and trying to get rid of lean codes. After replacing vacuum hoses, intake boots and other items I eventually gave up and it finally cleared.
06-29-2022, 10:17 AM | #4 |
Rep 58
I'm having a bad time 😂[IMG][/IMG]
StradaRedlands4998.50 |
06-29-2022, 11:50 AM | #5 | |
Rep 4,089
Yet, I have NEVER had an issue with Readiness Monitors NOT resetting, or passing Emissions Inspections every two years. George Last edited by gbalthrop; 06-29-2022 at 09:09 PM.. |
06-29-2022, 01:40 PM | #7 |
Rep 87
So, I have read that some codes will clear right away when you replace the parts that would fix the code. But others set a "permanent" code. These ones cannot be cleared by a scan tool. When you replace the faulty parts, and IF those parts were indeed causing the issue, each car has it's own conditions that need to be met in order for the ECU/DME to clear the permanent code(s). So, the drive cycle in relation to the clearing of these codes is variable, and depends on the code itself and what BMW engineers programmed as the conditions to be tested/met before the code can be cleared. Sometimes its as simple as turning on the car and while idling it will clear the code almost instantly. Other times, you must drive on the highway, at operating temperature, for 20-30 minutes, or for 40-50km. I'd say if the code does not go away by the 50Km mark, and you did a mix of idling, stop and go traffic, and highway driving, then the problem still needs to be addressed.
Edit: so, around 30-40 miles Edit 2: pending means the car/DME has noticed the issue/ abnormal behaviour of a sensor l, but the sensor reading is not in the range of being so abnormal that it becomes a permanent code *yet*. I hope that makes sense.
| N52B25 323i | BMW Performance Exhaust | Meyle HD Thrust Arms | Bilstein B6 Dampers |
| Bilstein HD Non-Sport Front Springs | Bilstein Non-Sport Rear Springs | Monroe RSM | | Lux Gold Angel Eyes | Sport Seats/Steering Wheel | Mishimoto Intake Boot (+69 HP) | |
StradaRedlands4998.50 beems581.50 |
06-29-2022, 05:22 PM | #8 |
Rep 4,324
I have yet to see a code or sensor on bmw that does not let you clear it if all is working order with key on car off
If the light/code immediately pops up after clearing the code, the fault is still there. That’s my experience anyways. If a code is present and a part was replaced but the code wasn’t cleared, it usually takes 2-3 complete drive cycles for the SES to turn off. |
06-29-2022, 09:24 PM | #9 | |
Rep 4,089
Only Fault Code I'm aware of that you can't clear is EGS 578E, Oil Wear Fault, which must be "cleared" by resetting the "Counter", as it is NOT a "Sensor Signal" Fault. George |
06-30-2022, 10:55 AM | #10 | |
Rep 1,893
I'm with you 100% - I don't understand why one would choose to pay for diagnostic software with limited capabilities when they can have the most sophisticated tools used by the factory for free! I have no idea what app beems58 is using and we cannot be sure which faults are current and which are not. That said, there's a DTML pump code at the top of the list (P240A) and a second DTML pump code at the bottom (2A18). I suspect that P240A is the generic OBDII counterpart of 2A18. In any case, both are hard electrical faults, not indicators of leaks. beems58, the DTML (evap) pump is easy to access behind the driver side rear wheel. The most likely (but far from only) possibilities are a bad pump, a fuse (F06, F74 or 17 depending on build date), a corroded connector or it is possible the wires to the pump were chaffed/cut through contact with a frame weld. I've never seen the latter but I know it's been reported a number of times. Easy enough to check the fuse and go take a look at the wires. |
07-09-2022, 01:13 AM | #11 | ||
Rep 58
I checked the wiring and it didn't seem like anything was broken or corroded. Though I did take it to BMW and they said the harness is corroded. So I'm just confused if I'm missing something. The code BMW gave me was the same P240A for the DMTL Leak. They changed the pump coded it and it didn't get rid of the SES or CEL light. They said they can change the harness etc but that costs an arm and a leg — plus they said that might not even fix my issue. Long story short, am I supposed to check the fuses first, then move to the wiring? Or should I just assume my wiring is corroded or cut somewhere? (E92 335i 08)[IMG][/IMG] |
07-09-2022, 04:42 AM | #12 | |
Rep 1,893
Yes, check the fuse first. Hopefully you have a DVM. If you cannot determine which fuse is the correct one, post the last 7 characters of your VIN number and I can tell you. Pretty easy to check the harness with a DVM - here's a schematic diagram for an N54 build date 09/2007 or later. EDIT: Are those FRM codes new or did you just decide not to share them in your first post? Do you have a headlight and brake light out or not? Last edited by dpaul; 07-09-2022 at 04:50 AM.. |
07-09-2022, 05:13 AM | #13 | ||
Rep 58
FRM codes? I didn't think the other codes were important because I'm just trying to get it to a point where I can pass emissions, then slowly fix the rest. The lamps are not out, all the lights work fine, they might be going out soon. |
