07-04-2022, 12:10 PM | #1 |
Rep 96
M3 Vs M4 awd comp
Has anyone had real world experience lining these two up ? It got me curious with the recent buzz around the 2.8 0-60 blast as reported by motor trend . I haven don't the break in service yet , but so far it feels slightly quicker than my m3 awd comp . *
07-05-2022, 12:13 PM | #3 |
Rep 615
Drives: Little of this, little of that
If all things are equal, outdoor temp, elevation, tires, gas level, same driver then I would think the M3Cx would win. It is lighter by about 90 lbs. Must be all the shit they ripped out for the stylish iDrive 8.
"It's not how fast you go, it's how you go fast"
G-Mann413.00 |
07-05-2022, 12:18 PM | #4 |
Rep 96
07-05-2022, 02:05 PM | #5 |
Rep 3,995
The cars are the virtually the same, but the M4 might have a slight edge.
Based on M3/M4 MY23 specs, the M4 is 1850 kg and the M3 is 1855 kg. Also, the roofline on the M4 is about 1.5" lower.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
Limegrntaln13476.00 |
07-06-2022, 09:48 AM | #6 | |
Rep 615
M3 Comp. AWD 2023 vs M4 Comp. AWD 2022 But as I said. All things being equal. Which they never are.
Last edited by Rux; 07-06-2022 at 09:52 AM.. Reason: Noted M3Cx model is not an M3. Might be wrong on the NA site? https://www.bmwusa.com/vehicles/m-models/m3-sedan/overview.html |
07-06-2022, 09:52 AM | #7 | |
Rep 3,995
2022 M3 weight was listed at 3,990lbs...so still heavier than the M4.
07-06-2022, 10:20 AM | #8 | |
Rep 615
Anyway, does not matter. I agree. They are so close the differences are negligible.
mr.angus278.50 |
07-06-2022, 03:20 PM | #9 |
Rep 10,167
Clearly a crap shoot in the real world... whoever gets the jump will take off and hold. Whoever has their car in the right settings will be key also.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
07-06-2022, 03:25 PM | #10 |
Rep 6,962
Drives: 2022 DG/BLk xDrive M4C Wk 34
I've seen nothing to indicate that the 2023 will be 100 pounds lighter. You would need to remove alot of comfort items for the car to lose 100 pounds.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
07-06-2022, 03:58 PM | #11 | |
Rep 3,995
Maybe before they included exec + drive assist, and now those are excluded and CCBs were added. Not hard to imagine a 100+ pound swing based on options.
07-06-2022, 08:55 PM | #12 | ||
Rep 6,962
YT: G Dubyou |
07-06-2022, 10:06 PM | #13 | |||
Rep 615
07-07-2022, 07:55 AM | #14 | |
Rep 570
Drives: '19 GLA45AMG(his) / '21 X3M40i
Granted, I bought the M4 because it was available at the time and coming off the delivering truck. If availability was not an issue, I would have chosen the M3. All based on the similarities in performance/specs + having the convenience of a 4 door. Now, what I DO NOT understand, is how a coupe is only (assuming the specs are accurate) 10lbs lighter than a sedan having 2 additional doors. Moreover, the two share the same exact exterior dimensions. And about the only specs that would negligibly affect performance are the headroom (assuming it directly affects roof height) and the minute rear weight bias on the M4. Germans must have pull off a Hocus Pocus engineering crap designing these two... LOL! So yeah, to answer the question, like mentioned already, both will perform the same (given all other variables equal).
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 |
Rux643.50 |
07-07-2022, 10:00 AM | #15 | |
Rep 615
The M3 is 3840lbs The M3Cx is 3890lbs. According the the website.
07-07-2022, 10:19 AM | #16 | |
Rep 615
M3Cx M4Cx Its a German mystery. iDrive8 weighs less? More bracing in the M4? Who the hell knows. I have not completely dug through The M3/M4 Technical Manual but I would put more confidence in that as opposed to the website.
GixY2K517.00 |
07-08-2022, 05:26 AM | #17 |
Rep 1,477
Drives: BMW M2
According to German sheets, nothing has changed with MY2023, the M4 is 5 kg lighter than the M3 and xDrive adds 50 kg to both.
The M4 also has some sound insulation material deletion. |
07-08-2022, 10:17 AM | #18 | |
Rep 3,995
If you compare the same model year for an apples-to-apples comparison, the 10lb delta in favor of the M4 remains. iDrive 7 does not weight 100lbs.
07-08-2022, 01:38 PM | #19 | |
Rep 615
But sure, whatever you said was right. No fucks given on my end sir. Looks like you ordered one of each. Why don't you weight them both and report back the results. Or don't...
07-08-2022, 01:47 PM | #20 | |
Rep 3,995
This is a versus thread, so comparisons of weight are fine. The difference between the 2 cars is still 10lbs, so either BMW is measuring the cars differently now, or the weight difference is not related to LCI-related changes.
