      07-08-2022, 08:09 PM   #1
M2 SoCal
BMW CCA ///M Chapter - Marketing Director
M2 SoCal's Avatar
1506
Drives: 2024 M2 (G87)
Interior lighting hidden feature
Voice command "set interior lighting to blue(or any color you want ) with white contour (or any other color you want)"
The door panel will be the contour color, pretty cool!
I've found that blue with white contour looks the best, but it's a good feature for any color
burkhacs136.00
TJZ67201899.50
redcars108.00
e36uulm94.00
Kay.Say22.50
      07-09-2022, 10:12 AM   #2
Lord Two Hats
Product Genius
Lord Two Hats's Avatar
Drives: 2016 340i,2022 M240i (ordered)
You can really mix other colors with it? I knew you could mix the colors with white but I didn't know you could do like lilac and blue or something like that
      07-09-2022, 10:39 AM   #3
M2 SoCal
M2 SoCal's Avatar
1506
I honestly haven't tried other colors, but I would think so
      07-09-2022, 11:35 AM   #4
Rdurty2
Drives: 2022 M240i
You can change colors via idrive settings. Not sure how this is a hidden setting, it’s right in the menus and pretty much everything in the menus can be operated via voice
      07-09-2022, 11:36 AM   #5
M2 SoCal
M2 SoCal's Avatar
1506
The contour feature is not in iDrive to manually select, only voice command.
TJZ67201899.50
P_Chris168.50
      07-09-2022, 11:39 AM   #6
Value
Value's Avatar
587
Drives: M240i
You can also code hidden colors most likely. Pink,red etc - Those weren’t available on the truck by default. I’ll try next week when I have the car
      07-09-2022, 03:38 PM   #7
HotsauzF82
HotsauzF82's Avatar
91
Drives: 2023 M240i X-Drive
Unfortunately pictures you posted aren't for the G42. The other vehicles in the G code lineup have the dual ambient lighting strip above and under the door handle.
G42 doesn't pic for reference below, so not sure how you would be able to select multiple colors like you can in the menu of the other G series vehicles.
      07-09-2022, 03:49 PM   #8
Value
Value's Avatar
587
Drives: M240i
That wasn’t the point or what I said . I said you can code and add hidden colors on almost every bmw. That was my Truck/X3 as I also mentioned and used it for a reference to show colors that aren’t there by default. I didn’t say you can alter the lighting and make it dual ambient as that would be impossible lol
Have you ever coded a car before? I’ve been doing it for a long time on many platforms.
      07-09-2022, 05:25 PM   #9
HotsauzF82
HotsauzF82's Avatar
91
Yes, I have done quite a bit of coding on both the VAG platform and the BMW platform. Most recently in my F82 and the G01. As the OP stated the dual color options ie: white/blue, In the G01 I was able to get the red and blue as the dual color combo, in addition to the factory options of white/bronze, white/orange, white/green, white/blue, white/lilac or all solid colors.
So then why would you post a picture of a single color in an X3, when the OP is stating that he was able to get blue with white contour lighting. I'm trying to understand which of the lights would be white and which would be blue as the G42 doesn't have the upper and lower strip like your X3 does.
      07-09-2022, 05:31 PM   #10
P_Chris
P_Chris's Avatar
169
Drives: 2022 M240i
2022 M240i  [0.00]
I can only get white as the other color
2022 M240i
      07-09-2022, 05:39 PM   #11
Value
Value's Avatar
587
Drives: M240i
I literally just stated you could code colors that are hidden by bmw. Not everyone knows about coding and hidden features and or different color options. Since you know about coding,you should know the picture i posted was in reference to the colors I coded that were hidden(as i said) You showed a picture of a G42 like I don’t know what the ambient lighting looks like lol - Not arguing/debating back and forth all day tho,it’s a waste of time ✌🏻
      07-09-2022, 05:44 PM   #12
M2 SoCal
M2 SoCal's Avatar
1506
Bummer
      07-10-2022, 06:33 AM   #13
HotsauzF82
HotsauzF82's Avatar
91
Ok, thanks for showing the picture as a reference point. Do you have the M illumination?
      07-10-2022, 09:21 PM   #14
bernard1414
Drives: A Volvo
X3 is not a truck....just saying....
      07-10-2022, 09:32 PM   #15
Value
Value's Avatar
587
Drives: M240i
Yeah it’s a SAV. Another genius that knows it all ….
      07-10-2022, 10:47 PM   #16
bernard1414
Drives: A Volvo
