Gas smell from driver side rear
07-17-2022, 11:46 PM | #1 |
Rep 9
I think i might have blown something after a pull… im pretty sure.
Anyone know what the problem is? I have a video of the problem that I will be posting on the forum if its allowed.. |
07-17-2022, 11:47 PM | #2 |
Rep 9
07-17-2022, 11:48 PM | #3 |
Rep 9
I will stop driving the car for a while since its a gas leak or something and it can go bad who knows when but this is the other video https://streamable.com/lip5ax
07-17-2022, 11:57 PM | #5 |
Rep 3,670
Sure looks like you got a puncture or crack in your gas tank but it's a little hard to tell exactly where it's coming from. Could be a fuel line or fuel pump has a bad seal. Looks most likely to me like a crack or pinhole in the tank though. Gotta get it on a lift and find out exactly where it's coming from.
Definitely smart to stop driving it before anything bad happens. Keep us posted! |
StradaRedlands5018.00 |
07-18-2022, 12:05 AM | #6 | |
Rep 9
07-18-2022, 12:51 AM | #7 | |
Rep 9
And i since its been about an hour, the gas stopped leaking when its off and only leaks when the car is on i think |
07-18-2022, 10:54 AM | #8 |
Rep 324
Pull the rear seat and tank access covers. The senders crack and leak. Look in the search function.
Look at this link: https://www.e90post.com/forums/showt...ht=fuel+sender Last edited by bmwbob89; 07-18-2022 at 11:01 AM.. |
StradaRedlands5018.00 Mike K332.00 |
07-18-2022, 12:28 PM | #9 |
Rep 3,670
If it only leaks when the car's running it pretty much has to be at the fuel pump or a split in the fuel lines. The pop could've been whatever you hit that caused it, or it could've been a backfire if the fuel pressure suddenly went wacky as the DME tried to compensate for the leak.
07-18-2022, 06:45 PM | #10 | |
Rep 64
07-18-2022, 11:16 PM | #11 |
Rep 9
https://streamable.com/fcfojt
This was the pull btw… got it on cam and everything |
