07-19-2022, 06:09 PM | #1 |
Joint Chiefs of Staff
24373
Rep 191,194
Burger Tuning BMS B58 BMW M240i M340i Competition Cold Air Intake
More Power and Dramatic Sound Improvement! Introducing the Burger Motorsports Competition Cold Air Intake for the B58 powered 2019+ BMW M340i and 2022+ M240i including xDrive models. Designed from the ground up to be the best in every aspect with over a year invested in street and track testing. This is the first intake for the Gen 2 B58 that follows a clean OEM+ look but has the intoxicating sound and performance of an open intake. Inside you'll find our proprietary renewable inverted cone performance filter, outside you'll find unsurpassed OEM fitment and quality. The BMS competition intake has a clear window on top for quick filter inspection, uses the OEM cold air inlet, and has a larger inlet hole on the cold side of the airbox for 40% more air and even more amazing sound! The factory heat shield is reused to keep those intake temps as low as the factory intended. This intake takes everything that is good about the factory intake and squeezes more sound and performance out of it while maximizing airflow to your B58 engine! Our Burger Motorsports renewable inverted cone filters not only outflow your stock paper filter and last the life of your vehicle they also include built-in velocity stacks. Velocity stacks allow even more air to be smoothly sucked into your intake system. Designed to work with OEM or BMS Billet Strut Braces and the BMS B58 Oil Catch Can. Features & Benefits • Adds up to 18 Horsepower • 40% more air than stock • Dramatic sound improvement • Improves throttle response • Retains OEM heat shield for low IATs • Retains OEM cold air ducting • Looks great under the hood • Renewable air filters • Made in the USA Vehicle Fitment BMW 2 Series • 2022+ G42 B58 BMW M240i and M240i xDrive BMW 3 Series • 2019+ G20 G21 B58 BMW M340i and M340i xDrive What's included? • (1) Airbox lid • (1) Airbox lid clear window • (3) Stainless Steel #4 x 3/8" long Pillips screws • (5) Stainless Steel M4 x 0.7mm thread button head hex drive airbox lid screws • (1) High flow airbox bottom • (1) Inverted cone BMS renewable performance filter (red or blue) • (1) High flow intake tube • (4) Stainless Steel M4 x 0.7mm thread button head hex drive Heat shield screws • (1) 4" silicone coupler • (2) 4" heavy-duty 90-110 hose clamps • (2) MAF sensor screws • (1) 11.75" piece of rubber weather stripping
07-20-2022, 10:31 AM | #4 |
24373
Rep 191,194
Its not
07-21-2022, 09:27 AM | #5 |
Rep 96
Does Burger have any dyno specs that can verify the 18 HP gain after the install of this CAI? I seem to remember that dyno tests of several popular CAI only resulted in HP gains of less than 10 HP. I believe the tests were done in Europe on various stock performance vehicles. If true, it's a nice HP gain just for adding a CAI.
07-21-2022, 09:29 AM | #6 | |
24373
Rep 191,194
kel44576.00 |
08-20-2022, 04:06 PM | #8 | |
24373
Rep 191,194
The B58 engine makes 10 HP from just the intake (lots of dynos have been posted). I can see this intake adding another eight or so with the right mods or upgraded turbo.
