How to put car on jack stands with only scissor jack
07-21-2022, 02:19 AM | #1 |
Rep 1
Hi!
I wonder where can I put jack stands if I use scissor jack to jack up my car? I know that there are 4 dedicated jacking points for jack stands but of course I cannot use them when I use scissor jack. My idea is to jack up rear of the vehicle and then put jack stands on the front jacking point. All I want to do is to jack up front of the car because I want to do oil change. Are there any other places where can I put those jack stands? Floor jack would solve this problem but unfortunately I don't have any.. |
07-21-2022, 04:38 AM | #2 |
Is it the shoes!?
3885
Rep 5,112
You can't, you shouldn't, and it's going to end in a disaster if you try doing this.
Buy a floor jack. |
Efthreeoh17427.50 bimmermech12355.00 tcphoto3555.00 lookalikehuuh706.00 Buug95917932.50 relative4612.00 shh1253.00 |
07-21-2022, 05:35 PM | #3 | |
Rep 462
07-21-2022, 08:50 PM | #4 | ||
Rep 1,183
07-22-2022, 12:14 AM | #5 |
Rep 3,053
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
07-22-2022, 10:07 AM | #6 | |
Rep 3,060
OP, it is always best to use a floor jack to raise the car because typical scissor jacks are not particularly stable and are prone to collapse. I own a low profile floor jack, jack stands and a set of ramps and try to use them in pairs for safety reasons.
StradaRedlands4998.50 Buug95917932.50 |
07-22-2022, 10:13 AM | #7 |
Rep 6,314
I think it might be doable but my worry is that you won't be able to lift the car high enough to fit the stand.
But hey you can try, when I used to only have one jack that didn't fit in front, I jacked up the rear sides one at a time and placed a jack stand up front. It works. |
RAZERS0.00 StradaRedlands4998.50 |
07-22-2022, 10:25 AM | #8 |
Rep 6,314
I've also been running jack stands in the style of those V style Duralast for the past 5 years with no issues. I use a a style with a locking pin which provides a bit more of peace of mind but I admit I'm always worried the sheet metal welds let go one day and it just splits open. But I do believe that's an irrational fear and that's probably impossible if the welds look good upon inspection before use and I don't exceed the weight limit.
07-22-2022, 06:21 PM | #9 |
Rep 423
Drives: 2007 E93 MT6
Well, I do think you can use a scissor lift safely if you do it right. I have an electrically powered scissor lift that runs of the 12v cigarette lighter power. I can activate it without having to get under the car while its doing its business. Need some small ramps to get front end up high enough to get started, though.
1. Drive car onto 4 inch ramps. 2. Place anti-roll chocks behind rear wheels; parking brake ON 3. Place scissor lift under front jack point, center of car, between engine and oil access panel. 4. Activate lift. 5. Place ESCO strands on left/right side. Car now safely supported 6. Remove scissor lift. 7. Remove underside splash guard. 8. Go crazy.
BMW: Doing Amazing(ly cheap) Things With Plastic (crap) Since the E90...
StradaRedlands4998.50 RAZERS0.00 |
07-22-2022, 09:14 PM | #10 |
Rep 3,053
I can get one end up pretty easily, but just gave up trying to get both up at the same time. Just can't get a jack under the front or rear when the opposite end is up. One of the reasons I gave up on doing trans fluid change.
For the wagon, it is so low I need to use crank jack to start one side up a little, then slide the regular floor jack under the central support. Works fine, but an extra step. |
07-23-2022, 02:21 PM | #11 |
Rep 1,322
07-23-2022, 02:26 PM | #12 | |
Rep 873
07-23-2022, 03:29 PM | #13 | ||
Rep 423
[IMG][/IMG]
Buug95917932.50 StradaRedlands4998.50 |
07-23-2022, 03:37 PM | #14 | |
Rep 873
07-23-2022, 05:40 PM | #15 |
Rep 3,053
Buug959 E93Dude I like your thinking here! Just enough to get it started!
07-23-2022, 06:07 PM | #16 | |
Rep 423
Please don't make me do a step-by-step instruction guide how to make these sharp, custom, organic, non-GMO ramps.....!
Buug95917932.50 |
07-23-2022, 08:29 PM | #17 |
Rep 3,053
Buug95917932.50 |
07-25-2022, 03:57 PM | #19 | ||
Rep 1,183
Doing the alarm retrofit and need to remove the left rear wheel. Figured I should jack up the rear using the rear diff jack location and put it on jack stands… |
07-26-2022, 09:55 PM | #20 |
Rep 7,215
I know inflation sucks and all.. but what does HF floor jack cost these days? They are safe and effective. It can't be worth your life - scissor jacks = the widow maker. I can't imagine owning a car without having at least that one cheap and basic tool.
