Nada DME?
07-24-2022, 11:54 AM | #1 |
Rep 11
Nada DME?
So I’ve been having an issue with my 328i where it will only crank and the engine will not fire. I get codes 2E7C on the DME and A0B4 on the CAS. The 2E7C is a BSD error and when I try to diagnose it on ISTA, it says that it’s a permanent fault and would like to know if I need to change the DME out. And help is much appreciated. Just trying to get my car on the road again :/
07-24-2022, 04:09 PM | #2 | |
e91Owner
425
Rep 1,130
StradaRedlands5015.00 |
07-24-2022, 04:12 PM | #3 | ||
Rep 11
07-24-2022, 06:29 PM | #5 |
Rep 11
07-24-2022, 07:33 PM | #6 |
e91Owner
425
Rep 1,130
You said you diagnosed it with ISTA. When you diagnose it, it will bring up the tree with all of the components on the BSD.
07-26-2022, 03:12 PM | #7 | |
Rep 11
[QUOTE=e91Owner;29146250][QUOTE=3azy92;29146109]
Sorry I misunderstood the question, but the DME, CAS, and FRM show up on the tree with fault memory. Also I'm getting 12.2 on the voltage reading |
07-26-2022, 06:41 PM | #8 | |
Rep 4,103
I'm NOT sure where/how you got the idea that "2E7C" fault code suggests you might need to replace the DME. The ISTA Definition for that code is: "DME: BSD Interface Signal, or BSD data bus communication fault" The BSD (Bit-Serial Data) bus connects the DME to the IBS (Intelligent Battery Sensor), OZS (Oil Condition Sensor), Alternator & Coolant Pump. This will take Multiple Steps, to get proper diagnosis over the Internet, but you/we will ALL learn something if you just take the time to do the steps in order, and SAVE/POST the ISTA ScreenPrints suggested. See part VIII on the last page of PDF for HOW to save and post screenprints. FIRST STEPS Suggested: 1) Follow the steps in the pdf, I through V; 2) Step III is "Display Fault Memory"; Save and Post ScreenPrint of Fault Memory screen; 3) Step IV is "Description" Tab display of selected fault code; display and SAVE ScreenPrint of Description Tab for each DME Fault; 4) Step V is "Details" Tab display of selected fault code; display & SAVE ScreenPrint of Details Tab for each DME Fault, as above. Go that far for now and Post ScreenPrints as attachments to your next post, and we can suggest "Next Steps". George |
StradaRedlands5015.00 Mike K332.00 |
07-26-2022, 08:59 PM | #9 | ||
Rep 11
I'm not sure if I can post a article from a website explaining exactly what BSD is and how it works. If I can someone please let me know so I can put it up on here. But in that article, it explains how the Electric Coolant pump, Oil level sensor, Alternator, and Intelligent Battery Sensor is connect via the BSD and if I am getting the 2E7C (BSD data bus communications fault) code, I can work backwards and disconnect these 4 things to see if there is a difference within the fault readings on ISTA. I disconnected the IBS and Alternator being the easiest to access, and sure enough!!!! The 2E7C code went away and showed the IBS and Alternator disconnected. Plugged the the IBS sensor and everything went to $#!+ again. The IBS was faulty and was throwing everything off. Question - if I remove the IBS will that still stop the car from turning on? |
07-27-2022, 01:42 PM | #10 | ||
e91Owner
425
Rep 1,130
[QUOTE=3azy92;29152631][QUOTE=e91Owner;29146250]
07-27-2022, 01:58 PM | #11 | |
Rep 4,103
1) Single Red wire in black sheath that goes to LARGE Blue connector plugged into Center-Rear of Rear Power Distribution Panel, on top of the battery. That provides battery B+ signal to the IBS so it can measure Voltage; 2) Two-wire connector, also blue but smaller, (three pins but 2 wires) that is the BSD wire and a KL15 Wakeup wire to/from the IBS, connector to chassis wiring harness above & outboard of the battery. Questions: A) WHICH of those two IBS connectors did you disconnect? B) Before you disconnected one/both of those connectors, Starter Cranked engine, but engine would NOT fire? C) Disconnecting ONE/BOTH of those connectors allowed Engine to fire when cranked? D) What is NOW disconnected, and does engine start/run NORMALLY? E) What fault codes do you NOW have with whatever is NOW disconnected? Is LAST ISTA Screen Photo attached to your Post #9 the current Fault Memory List? Your IBS MAY/may NOT be faulty. You MAY have a fault in the KL15 Wakeup wire. You already Effectively/Electrically REMOVED the IBS by disconnecting whatever you disconnected. That disconnection AT LEAST corrected the BSD line Fault (assuming your Alternator BSD connector has been RE-Connected). There is NO reason to physically REMOVE the IBS from the vehicle. WHY disconnecting whatever you disconnected worked to allow engine to fire depends upon WHAT you disconnected. Disconnecting EITHER IBS blue connector will prevent the IBS from working as intended. However, AFAIK, the Alternator will/SHOULD revert to a "Default" Voltage output, in range of 13.8V to 14.0V (you can measure that with DMM or ISTA Live Data), and keep your Electrical System & battery functioning at a nominal level (probably NOT "Optimal"). We would like to help, but we need to know details of what was done. Otherwise, we may just be spreading MIS-information. George |
07-27-2022, 02:00 PM | #12 | |
Rep 1,893
07-27-2022, 02:12 PM | #13 | |
Rep 4,103
Actually, there have been MULTIPLE claims/posts that disconnecting IBS allowed Engine Crank/Start where there was NONE BEFORE disconnect. NO ONE has taken the time to address the details and explain WHY. Perhaps if OP, who has ISTA, will do that in THIS CASE, we can learn WHY. George |
07-27-2022, 02:24 PM | #14 |
Rep 1,893
1) there are multiple claims that unplugging the IBS can allow a car that would not start to suddenly do so. They make no sense. You understand electricity as well or better than I do - make sense of the IBS claims if you can.
2) Not sure what you mean about differing understanding of the OP’s post. In post #1 he says his car cranks but does start. He says his only codes are the BSD code and one non-diagnostic CAS code. After you ask for a screen print, all of a sudden he has valvetronic codes very likely the reason his car does not start Last edited by dpaul; 07-28-2022 at 02:01 PM.. |
07-27-2022, 03:02 PM | #15 |
Rep 1,893
3) for the sake of completion - yes there is an obvious IBS failure mode which will prevent the car from cranking but will also affect multiple systems - the IBS introduces a very low resistance in series with the negative cable. The flow of current through this low resistance results in a very small voltage drop which is measured and reported to the DME. If the "low-resistance" element of the IBS should open, no current can flow and no cranking will happen. Still, simply "unplugging" the IBS (removing its connection to the BSD bus), cannot affect starting.
07-27-2022, 03:51 PM | #16 | |
e91Owner
425
Rep 1,130
07-27-2022, 05:07 PM | #17 |
Rep 4,103
I'm NOT trying to impugn ANYONE'S knowledge here, particularly dpaul or e91Owner. I was trying to be humorous, as I interpreted OP's LAST post (Post #9) as suggesting (although NOT stated) that the engine fired & started with the "IBS disconnected", whatever connector that referred to.
I would like to know WHY disconnecting the IBS (somewhere ;-) allows Starter to Crank or Engine to fire when cranked, where that did NOT happen before disconnection. I do NOT pretend to know any more than you do. I just want to know OP's DETAILS, so MAYBE we can learn something. George |
07-27-2022, 05:36 PM | #18 | |
Rep 1,893
If it is true, I'll buy you a beer. So, OP - did unplugging the IBS allow the car to start? |
07-28-2022, 06:54 PM | #20 |
e91Owner
425
Rep 1,130
I dunno man. It works all the time. For whatever reason, that simple part seems to wreak havoc on the BSD when it goes bad. I'll be interested to see if the same is true here as well.
