      07-28-2022, 09:49 AM   #1
Team Tonka
Drives: 2022 G80 M3 xDrive Comp.
PPF Question
My car has full PPF on it, there are some areas that aren't super visible - like under side skirts for example - that the PPF has peeled up a little bit. I've heard there is a certain primer that can be used to help hold those areas down? Can anyone point me in the right direction what this primer is (whom to purchase from), and how to properly use it?
And, when removing or replacing the PPF in the future - can this primer be removed without ruining the paint?
      07-31-2022, 09:48 AM   #2
Team Tonka
Tried the primer, that didn't work...
      07-31-2022, 07:56 PM   #3
astroricardo
astroricardo's Avatar
Drives: 2022 M3Cx TR/Tartufo
You try contacting the place that did it?
      08-01-2022, 01:23 PM   #4
Wo-Wo
Wo-Wo's Avatar
United Kingdom
325
Drives: BMW M4 Comp Coupe
This^
I’ve had 10 plus cars PPF’d and never had this issue. They can trim the lift part it’s not seen really easily.
Wo-Wo Detailing Accessories
www.wo-wo.co.uk
      08-01-2022, 01:48 PM   #5
nearwater4me
Drives: '22 G82 Base
Try Pro Bond Adhesive Promoter.
I've used it on peeling edges with great success.
Make sure you don't use too much. I've used a sharp-edged nylon q-tip to apply just a tiny bit.
Took care of the peeling edges around the front bumper above the grill/under the hood.
I'd be careful applying to bodies that are visible.
Areas I used are under the panels and wrap arounds like under the wheel well, etc.
