Help with VC Gasket
07-30-2022, 10:00 AM | #1 |
Bill Mo
Rep 18
Help with VC Gasket
New to forum and BMW. Purchased a 2007 328i to use as second vehicle. 65k miles. Had small oil leak so first project is to replace valve cover gasket. Removal was good except snapped one ground fastener. Have tried PB Blaster, Vice grips, stud removal tool but won't budge. Plan to use some heat next. Any other thoughts?
07-30-2022, 11:58 AM | #2 |
Rep 323
Use good vice grip pliers. if can't get it out, this bolt extractor saved me few times...
https://www.autozone.com/tools-and-e...E&gclsrc=aw.ds |
StradaRedlands5013.50 |
07-30-2022, 01:54 PM | #4 |
Rep 5,022
Slot it with a dremmel then hit it with and impact screwdriver.
StradaRedlands5013.50 tcphoto3556.50 |
07-30-2022, 02:11 PM | #5 |
Rep 3,063
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Wonder why it is so frozen in place... not something I've read about happening much.
Sorry you hit that jackpot... |
07-30-2022, 03:21 PM | #6 |
Rep 5,022
07-31-2022, 03:53 PM | #9 |
Rep 2,109
In my experience PB Bluster and similar works well on steel to steel but not so good for steel fastener in aluminum. I don't know anything good for that except heat and working it back and forth with patience.
08-01-2022, 08:15 AM | #10 |
Bill Mo
Rep 18
Marvinstockman: Ground is one of the 3 interior fasteners to secure the valve cover. Has another ground fastener so am guessing that it's maybe 3 and 3 for the ignition coils.
PhaseP: Same experience with PB Blaster. Not much help here. I think patience will be the key. |
08-01-2022, 08:18 AM | #11 |
Rep 400
Drives: 2011 e91 328i RWD
How about threading the stub with a die, and then using the two nut trick to back it out of there with a bit of heat?
08-02-2022, 11:23 AM | #12 |
Bill Mo
Rep 18
Thanks for all the suggestions. I guess patience was not one of my choices. Snapped again with the stud extractor. Showing new part vs two pieces from the old part. Looks like still about 1/2" still in there. Will need to get out the drill. Sigh!
