Help!! 2E7C
08-04-2022, 09:42 AM | #1 |
DIY addict
Rep 24
Help!! 2E7C
Hi ppl... i know this has been discussed before... but I'm stuck
2008 335i manual... battery died... car wouldn't even turn over... so changed the battery and registered it... everything is fine... went for a drive at night... about 1 hour in... a DSC fault came yp on the dash... a few seconds later the radio started fading... then the dash lit up like a christmas tree... car overheated... went into limp mode... pulled over turned it off ... scanned it every fault was registered... tried to start the car and the battery was dead... so naturally the alternator was dead... next day replaced the alternator... cleared the codes... changed the engine oil... and lo and behold i can't check the oil level... it says inactive.. Scanned the car again and the code 2E7C came up... jow inam familiar with that code... soni started troubleshooting it... did every diagnostic tricknin the book... unplugging and replugging... clearing and rescanning... and could not find the issue... waterpump is new bybthe way... ibs sensor also changes recently... all fuses checked... ground checked.... The waterpump comes on and off even when the car is turned off... which will drain the battery for sure Any ideas??? Thanks |
08-04-2022, 10:32 AM | #2 | |
Rep 4,088
2E7C | BSD bus Communication fault | msd80 https://bmwfault.codes/XMLDiagView?d...UAMwAxADAANAA= See the "Service Notes" in that Fault Info Link for HOW to test to determine the CAUSE of the issue. Your BSD Bus connects the DME Module to: 1) OZS Oil Condition Sensor (Oil Level Sensor); 2) Alternator for control of Voltage Output (you DID replace the Alternator with a Bosch "BSD Alternator"?); 3) Coolant Pump; 4) IBS (Intelligent Battery Sensor) which provides Battery Voltage/Temp info to the DME. Please let us know what you find, George |
08-04-2022, 11:49 AM | #3 |
DIY addict
Rep 24
Thank you gbalthrop for the reply... i already did all of that... no matter which item i disconnect the fault remains... i checked the connections and cleaned by contact cleaner... fault remains... I'm afraid it might be a DME issue... but there are no DME internal codes... tomorrow I'll resume troubleshooting... thanks alot
08-04-2022, 02:59 PM | #4 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
11-05-2022, 12:43 AM | #6 |
Rep 72
Drives: BMW 335i
Thanks for report your solution.
