E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > High temp limp mode
Reply
      08-04-2022, 01:52 PM   #1
lee.j.hill
Drives: bmw e93
High temp limp mode
I started my bmw e93 325i 3L and drove it 2/3 miles then I got a warning on the idrive that the engine temp was high and it went in to limp mode, the temp on the dials was reading normal about 75/80c
I did a scan and it showed a error for thermostat activation.
I have tried to activate the coolant pump but it doesn't seem to do anything.
I have looked for the 30amp fuse in the ecu box under the bonnet but there is no fuses in mine just the ecu and a single relay.
Could this be a thermostat stuck in the closed position or likely to be something else?
      08-04-2022, 02:16 PM   #2
trohde78
trohde78's Avatar
74
Drives: 2007 e92 335i 6MT
It sounds like the coolant pump is bad. It won't get hot enough to even open a thermostat in that short of a distance. It probably detected that the coolant pump was inop and sent it into limp mode. Mine went out like that with no other warning on my '09 335i.
      08-13-2022, 05:47 AM   #3
lee.j.hill
Drives: bmw e93
I changed the water pump and thermostate and bled the system, i have filled it with water only and drove it for4 days no problem then yesterday i had a temp warning again . could this be because i only filled the system with water?
I only did that so i could make sure all was good before putting coolant in
      08-13-2022, 03:51 PM   #4
trohde78
trohde78's Avatar
74
Any codes?
      08-14-2022, 04:35 AM   #5
lee.j.hill
Drives: bmw e93
nope no codes. I have tried to activate the water pump and it doesnt seem to be running.
its funny it worked all week then stopped
      08-14-2022, 06:18 AM   #6
lee.j.hill
Drives: bmw e93
is the genuine bmw water branded PIERBURG ?
      08-15-2022, 02:22 PM   #7
trohde78
trohde78's Avatar
74
It looks like the BMW version is made by VDO, but the Pierburg one has an all aluminum housing, which should be better.
Reply
e90post
