08-25-2022, 10:08 PM | #1 |
Rep 98
Mirror caps removal
I got the mirror caps from AE, but I'm not sure how to remove the existing ones. I watched a bunch of YouTube videos, which all say I should pry the glass out. I used as much force as I thought was reasonable to pry it out with a pry tool but it would not come out. Is there something I'm missing here, or I'm not applying enough force? Basically moved the mirror up and towards the car then put a pry tool at the bottom and try to lift it... any tips would be appreciated!!
08-30-2022, 05:26 AM | #2 |
Rep 110
You don't need to pry the glass out, trim removal tool along the top, pop the first clip, then go to the lower section at the front of mirror) and finally the pointed tip has a clip too
08-30-2022, 10:57 AM | #5 |
Rep 110
Be mindful I picked up some ae mirrors and they didn't fit, if you post a picture of them I'll be able to tell if they will fit (the pointed tip section was incorrect)
09-01-2022, 12:49 PM | #6 |
Rep 606
09-02-2022, 04:48 PM | #8 |
Rep 98
Well I just managed to open the mirror to find out it doesn't fit womp womp.. ugh. Luckily it's only $27 lost. So nothing that will work from aliexpress? The other option is from Monaco for $289...
09-02-2022, 10:53 PM | #9 |
Rep 428
Can any post pictures of what doesn't fit and why?
yuvalt maybe a link what you tried Thanks!
'22 M240i BSM, Shadowline, Black 791M wheels, Red Calipers, ///M Carbon Front Lip, ///M Carbon Spoiler, ///MCarbon Door Sills, Milltek Catback w/Black Tips, Dinan Carbon Intake/Engine Cover, AA Catted DP, Dalher Valve Controller, OEM+ Strut Bar, Red Start/Stop, Floating center caps, TLG Mud Flaps, Black Badges, Led Projectors, 50th Emblems, Carbon Diffuser/Mirrors w/smoke signals/Side Wings/Cooling Shroud/KIES fire extinguisher, Yellow DRL
09-03-2022, 02:14 AM | #10 |
Rep 110
Correct:
https://drive.google.com/file/d/1DU3...w?usp=drivesdk Incorrect: https://drive.google.com/file/d/1DXN...w?usp=drivesdk Just to add I'm RHD not left hand drive |
Bots412.50 Vudumonkey25622.50 |
09-03-2022, 08:55 AM | #11 | |
Rep 428
09-08-2022, 12:12 PM | #14 |
Rep 98
09-11-2022, 01:46 AM | #17 |
Rep 98
09-14-2022, 10:25 AM | #18 |
Rep 60
Drives: BMW M240i
any g80 mirror caps fit the g42
09-15-2022, 02:41 AM | #19 |
Rep 357
He is correct ^ G80 M3 caps fit,however. On AliExpress 90% of the caps listed for G80 are actually G20 caps which look identical from the outside. You MUST get or see pictures of the inside of the caps to make sure the tip is open and not closed
I can share my vendor once I install them,but I don’t want other people buying them before I test them myself. That’s why I haven’t posted it yet. |
09-15-2022, 07:56 AM | #20 |
Rep 2,070
I found a set on AliExpress that may work
US $115.44 20%OFF | For M3 M4 G80 G82 G83 2021 2022 Real Carbon Fiber Car Side View Mirror Housing Cover Caps Replacement Ox Horn Shape https://a.aliexpress.com/_mKbVMyc |
09-15-2022, 08:00 AM | #21 | |
Rep 98
09-15-2022, 08:51 AM | #22 | |
Rep 357
You guys might need glasses lol - I tried 🤣 |
