08-31-2022, 03:32 AM | #1 |
Rep 1
AC 11 KW wallbox Charging problem in hot weather above 34 - 35 degrees.
Hello,
I am having trouble charging my 2021 model IX3 with AC 11 KW wallbox in hot weather above 34 - 35 degrees. I get a warning that it cannot be charged, contact the service. The charging speed drops and after a while the charging stops completely, it gives a warning that it cannot be charged. I don't get this alert when the air temperature drops. Has anyone encountered this problem? |
08-31-2022, 08:09 AM | #3 | |
Rep 360
To OP: Try a different charger as a start. If the problem is still there, there might be an issue with the cooling system on the car.
´22 iX3 M Sport "Charged" - Cashmere Silver
´22 Mini Cooper SE "Yours Trim" - Island Blue |
08-31-2022, 09:54 AM | #4 |
Rep 103
Have you done the 03/2022 update (currently available at the dealer only to my understanding)? In the previous software versions there was a recall which caused the cooling system not to function properly.
