09-01-2022, 09:29 PM | #1 |
Rep 15
M340 grille swap
I’ve decided I prefer the slat grille to the diamond grille so I want to swap out
2 quick questions: Since the replacement slat grille doesn’t have active dampening, is there anything I need to worry about to avoid throwing error codes? While I’m in there, I want to vinyl wrap the crash bars. Is there a heat consideration there? Like a grade of vinyl that should be used? |
09-02-2022, 06:26 AM | #2 |
Rep 1,480
Drives: 2020 M340Xi (G20)
kirothehero ,
I changed out the Cerium gray grill on my car. The visible grille is plastic & merely sits in front of the active grille, which automatically opens thermostatically. BTW, it was "fun" to remove old one -- several good videos! As for your 2d question, sorry, can't help Hope that helps!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
TheJungatron361.00 |
09-02-2022, 12:22 PM | #3 |
Rep 15
Oh thanks! I had watched some videos and thought the active grille was part of the diamond grille. That helps a ton!
