Another VCG?!
09-29-2022, 04:24 PM | #1 |
Rep 388
Another VCG?!
So I changed the vcg on my 2011 328xi not quite two years ago due to an oil leak on the right side of the motor that kept hitting the exhaust manifold. Now it's leaking AGAIN as of about 2 weeks ago. I don't know how this could happen in such a short span of time. I ordered the gasket from FCP, so it'll be free when I return the old gasket, but it's a huge pain to have to change again.
Anyone else experience a failure this quickly? I had the car parked for about 3 or 4 months recently while I waited for KW to rebuild my coil overs…could sitting for that period of time without the motor running cause the gasket to prematurely dry out? |
09-29-2022, 05:50 PM | #3 |
Rep 388
Good point. Thanks for your reply!
I guess I could go around and check the torque on each of them before tearing everything apart. |
09-29-2022, 08:33 PM | #4 |
Rep 388
Though I find it odd that it would be leak-free for almost 2 years and then start leaking due to the bolt torque not being correct. I used a torque wrench for the job.
Anyone else have any thoughts? |
09-30-2022, 01:40 PM | #5 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
Is your valve cover original? It's probably warped. Or is currently on the move, hence the torque being off.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
RNByrd3198.50 |
09-30-2022, 01:41 PM | #6 |
Rep 388
09-30-2022, 04:51 PM | #7 |
Parts Pro
65
Rep 134
Drives: 2007 BMW 328xi 6MT
Ive also switched from 5W30 to 5W40, so at operating temperature the oil will be thicker and harder to leak
10-02-2022, 01:46 PM | #9 |
Parts Pro
65
Rep 134
When you installed your valve cover gasket, did you use some RTV in the corners of the bends of the gasket. That is where it tends to start leaking first
RNByrd3198.50 |
10-07-2022, 09:09 AM | #10 |
Rep 388
10-07-2022, 09:10 AM | #11 |
Rep 388
Yes, I did use RTV. Thanks for your reply!
chilledn5265.00 |
10-07-2022, 12:11 PM | #13 |
2216
Rep 2,219
Drives: '08 128i
Not affiliated, but I've been having good luck with the eBay aluminum valve cover
https://www.1addicts.com/forums/show...&postcount=191
RNByrd3198.50 |
10-08-2022, 09:20 PM | #15 |
Rep 589
Yeah it's worth checking carefully to make sure it is actually leaking from the VCG. Sometimes even spilling oil while filling it will cause it to drip down and eventually look like the valve cover itself is leaking. If you haven't done so already I'd say to clean everything that you can on the top and try to carefully check where it's coming from before you go forward with doing the VCG again.
RNByrd3198.50 |
10-09-2022, 12:54 AM | #16 |
Rep 7,215
No good shop I have ever heard of would replace the gasket without also replacing the cover too (at least the plastic ones). And I think for exactly this reason - they plastic covers warp, crack and leak on their own, even if the gasket itself hasn't failed yet.
RNByrd3198.50 |
10-09-2022, 12:57 AM | #17 | |
Rep 7,215
RNByrd3198.50 |
10-09-2022, 10:11 AM | #18 |
Parts Pro
65
Rep 134
When doing the stage 3 intake manifold I also upgraded to a used magnesium cover with the external oil separator. This is due to it being more reliable then the plastic and not worrying on any cracking. Installing wise needs slight adjustment but afterwards have not had any problems.
RNByrd3198.50 |
10-09-2022, 05:09 PM | #19 | |
Rep 388
