Replacing hifi amp?
10-06-2022, 03:40 PM | #1 |
Rep 2,869
Replacing hifi amp?
I believe my hifi amp has died. 2008 328i sedan. premium hifi sound system, no i-drive.
My car has no sound (no chimes or anything) and the headunit is completely dead. I have a non-idrive professional headunit. My sat radio module died a few months I fixed with a bypass MOST loop... however this time, with no power to my headunit and no sound, i have to think it is my amp? What are the best options here? Replace with a used amp? Where should I buy this? I assume I will have to code this amp to the car which I have no idea how to do, so any help there is appreciated. Any way to buy an aftermarket amp and have it run the sound system including bluetooth, door chimes, etc or an OEM replacement the best/only option?
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
10-06-2022, 05:02 PM | #2 |
Rep 13,122
If the Head Unit is truly dead or does not have power you need to fix that first.
You can get the Hi Fi amps cheap on Ebay (less than 100.00)no coding required its and Analog Amp. Easy to replace there is only one Lever you have to throw to disconnect it. If you you want to upgrade to and aftermarket amp you can do that to but you will have to spend some Bucks. If you upgrade the amp you will get better sound but to get great sound you need to replace all the front speakers. Bluetooth and USB are not considered amp functions though there are a few that allow this. (You would have to go direct from your phone for sourcing and control) If there is no power to head unit and you see no display that sounds like a head unit problem. There is a stereo sub forum here where a there is a lot more detail on this stuff. https://www.e90post.com/forums/forumdisplay.php?f=27 BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/attach...1&d=1209780865 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://technicpnp.com/menuDiagrams/d...e90_92_93.html http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...3&d=1169133185 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://www.e90post.com/forums/attach...4&d=1278871872 http://www.e90post.com/forums/showthread.php?t=343673 https://www.bimmerfest.com/threads/e...n-752.1275694/ base system wiring pre/post 3/09 https://www.google.com/url?sa=t&rct=...tDpLJPcGkw_ui_ Base System Guide http://www.e90post.com/forums/attach...5&d=1493273253 examples http://www.e90post.com/forums/showth...ighlight=level http://www.m3post.com/forums/showthread.php?t=540446 http://www.e90post.com/forums/showth...hlight=technic http://www.e90post.com/forums/showthread.php?t=532585 http://www.e90post.com/forums/showthread.php?t=833581 http://www.m3post.com/forums/showthread.php?t=443043 http://www.e90post.com/forums/showthread.php?t=324214 https://www.bimmer-tech.net/blog/ite...-audio-for-bmw http://www.e90post.com/forums/showth...hlight=level+3 Currently amp/dsp combo's are the thing such as a Audiotech/Fisher 86dsp or BMW7 there are many other types. Hi Fi is 6 channel amp that uses differential 5 volt outputs essentially reduced speaker outs . That needs to be fixed first. There is a a fuse at the back of the Head Unit in addition to fuses in the cabin fuse board. If the battery is low the IBS can turn off power to the Head Unit. https://www.google.com/url?sa=t&rct=...,d.cGU&cad=rja Last edited by ctuna; 10-06-2022 at 05:19 PM.. |
10-06-2022, 06:10 PM | #3 |
Rep 740
If you narrow it down to the amp, I've got a good HiFi amp you can have. Ship collect or pickup is fine.
But honestly, take the opportunity to upgrade the amp to JL/BavSound/Etc. Way better. |
10-06-2022, 06:11 PM | #4 |
Rep 2,869
Thanks for the info
My headunit (no I drive) does not display anything… the little screen is completely blank My vehicle makes no electronic sounds - no door chimes, no radio/cd etc Does the amp power the headunit? I’m hoping it’s as simple as this and can replace my amp Not sure how I can test this? I have to imagine the headunit replacement would be much more expensive and would require some type of coding to work properly? I’d l don’t care about my sat radio, I would like BT phone to work but not going to jump through hoops for it |
10-07-2022, 01:22 AM | #5 |
Rep 13,122
No the amp does not power the head unit . Power comes from the 12 volt battery
the way it does in any car but it's not direct. I don't beileve there is car I have ever seen that uses the amp to power the head unit . If the Head unit does not light up either is is not getting power or is bad. |
AllBlackBimmer817.50 |
10-11-2022, 11:26 AM | #7 | |
Rep 58
So, there is no way the AMP is responsible for the head unit not powering up. A blown fuse could be responsible, however. The amp is also continuously powered, even when the car is off. There is a yellow LED inside the amp that is illuminated whenever the MOST connection is active. |
10-11-2022, 05:24 PM | #8 |
Rep 13,122
Number 1 all attention should be shifted to the Head Unit if it's Dead.
Number 2 if the OP identified the system is Hi Fi there is no most connection to the all analog Hi Fi amp and the Hi Fi system which only has 6 channels. The Hi Fi amp has no status LED's |
