Fuse box making crackling noise
10-18-2022, 02:56 PM | #1 |
Rep 56
I have been experiencing battery drain and my fuse box will make a cracking noise while the battery is dead and I am charging it… it is constant. Also it will make that noise for a couple seconds when the battery is charged and I insert the key phob. Please help! Any ideas?
10-18-2022, 03:05 PM | #2 |
Rep 19
You might have loose connection in B+ cable which ends in
fuse box. If you wiggle the cable does the crackling go away and are you sure that your battery is drained dead ? You lose all electricity if B+ cable is loose and it's common fault |
