      10-20-2022, 03:39 PM   #1
PrinterGirl
Drives: M240i
Low profile dashcam install
After my recent encounter with a truck on the expressway I wanted to share the details on my dashcam install for anyone that might be looking for information / ideas.
I wanted something as low profile as possible and I hated the idea seeing double sided tape from the outside of the windshield. I ended up using black vinyl decal stock from a local craft store (Michaels in my case) to blackout the area above the rearview mirror matching the contouring of the existing light filtering dots and attached the camera to that. Total cost was under $5. The blacked-out area looks like it came that way from the factory and nicely conceals the cables and upper half of the camera. It not invisible but unless you are looking for a camera you won’t notice it.
I used a fuse tap kit for power that allows me to use the parking mode of the camera. This requires a constant power line and one accessory (switched) connection. The fuse box is in the passenger footwell.
Fuse 24 for constant power
Fuse 46 for accessory (front cigarette lighter)
*note this is from my 2022 M240i, BMW may change the numbering on different models/years/factory options
Zip tied it all to the factory wire harness so there is no interference with the airbag and installed the rearview camera tucked up in the corner of the headliner. Again, from the outside it just blends right in, you can’t see the rear camera whatsoever from the rearview mirror.
TJZ67201889.00
PP3121375.00
Kay.Say22.50
Ruebarb416.50
XC3LLR82089.00
      10-20-2022, 04:23 PM   #2
PP3121
Drives: 2023 M240i
Great work. Thanks for sharing your approach.
The cameras are hidden nicely. Actually, I still can't make out the rear camera due to the reflections.
May I inquire which model camera you are using? I have read so much that I can't quite make up my mind anymore!
      10-20-2022, 04:31 PM   #3
PrinterGirl
Drives: M240i
The rear camera is just to the right of the break light. It's sort of barrel shaped.
I used a Ddpai Z50, really good physical build quality but the software is lacking. Over all it's ok for the cost and being 4k, not 100% sure if I would buy it again or not.
PP3121375.00
      10-20-2022, 04:38 PM   #4
sandrik93
Drives: '23 M240i RWD
Thanks for sharing.
I used the g80 wiring mentioned in the other thread. Fuses 29 (batt) and 70 (acc). How long does it take yours to go into parking mode?
      10-20-2022, 04:52 PM   #5
PrinterGirl
Drives: M240i
Originally Posted by sandrik93 View Post
Thanks for sharing.
Its around 8 minutes which I actually prefer so if I get out of my car on the side of the road it's still on for a bit.
There is the option of tying it into terminal 15 that is only live when the engine is running but you can only get to that in the trunk fuse box.
      10-20-2022, 05:03 PM   #6
sandrik93
Makes sense. Probably why BMW's dashcam install manual indicates that wiring is going to the rear fuse box.
      10-20-2022, 11:51 PM   #7
inc235
Drives: 23 M240i RWD
Anyone considering hooking up a constant running dash cam (including OP): it can make your car battery die in like 2 yrs or less. Just know that it drains battery much faster than you'd think. (IDK maybe BMW will replace the battery under warranty lol)
A lot of cars in S. Korea have constant loop dashcams (with parking surv. mode) and their main complaints are that their battery died in like a yr or two.
PP3121375.00
      02-03-2023, 06:58 AM   #8
Crazy One
Crazy One's Avatar
93
Drives: G42
Hi,
Can you please provide some photos how to open the access to the fuses and how you hidden the cable?
      12-05-2024, 04:11 PM   #9
Baby_G42M
Drives: '25 G42
Any updates? I have a 2025 M240i xdrive with what fuse to tap? I'm thinking
and not too sure which to tap for constant without draining anything important. any recommendation?
      12-05-2024, 05:33 PM   #10
MPR
MPR's Avatar
2002
Drives: 22 M240i
Ive been itching to install a dashcam, what is the consensus on a solid but affordable camera model ?
      12-05-2024, 06:20 PM   #11
Pentland
Drives: BMW M240i (G42)
BlackVue.
MPR2002.00
