10-24-2022, 07:03 PM | #1 |
Rep 66
winter wheel size question
A few years ago, I joined in a Bimmerpost group buy for Apex wheels for winter use on my OG '18 M2. They are 18 x 9", ET31. Anyone know whether these will fit on a G87? Thanks
10-24-2022, 09:08 PM | #2 |
Rep 502
OEM winter setup for the G80 is 19x9.5 ET20 both front and rear. Safe to say that would be the OEM setup for the G87. You can use spacers to cover the offset delta but not sure if your wheels can clear the brakes. I would suggest searching the G80 forum to see if anyone was able to use a setup similar to yours.
BMW CCA Member ID: 592739
10-24-2022, 11:52 PM | #5 |
Retired Major
1062
Rep 764
What is the bolt pattern?
2023 G87 ///M2 (production began Jul 4th 2023) 2008 E90 335i | Silver Grey | Terra | Piano Black | 6MT | ZSP | ZKO | ZAT | ZKI | ZPL | ZKL | |
10-25-2022, 12:01 AM | #6 |
Rep 291
Albator_IIII1062.00 |
10-25-2022, 09:59 AM | #7 |
Retired Major
1062
Rep 764
Thanks.
Is 5 x 112 the new pattern moving forward? Has it been confirmed on the G87 as well?
10-25-2022, 10:13 AM | #8 |
Car Geek
4255
Rep 3,902
Yes, the switch started across the range for the 2018 model year with Gxx models and looks like the F2x was the last to have the old 5x120 bolt pattern when it went out of production in 2021. There had been selective use of 5x112 before 2018 on certain models such as the i3, though.
12-09-2022, 11:58 AM | #10 |
Rep 502
Tire rack has the 275/35/19 Blizzak LM32s in stock again, they are a great deal and they should work great as a square setup with a set of winter wheels per the G80 forum. Go get them before they are out of stock...
jordan24c129.00 |
12-09-2022, 12:42 PM | #11 |
Rep 296
I'm hoping someone wants to trade me their stock front wheels for my stock rear wheels so they can have 20s all around and I can have a cheap winter set. Think about it, folks
12-09-2022, 12:57 PM | #12 |
Rep 1,843
12-09-2022, 01:18 PM | #13 | |
this is the way
20007
Rep 8,949
12-09-2022, 01:38 PM | #14 |
Rep 761
What's wrong with running the stock staggered size for all season or winter tires?
12-09-2022, 01:50 PM | #15 |
this is the way
20007
Rep 8,949
You typically want a square setup for winter since narrower winter tires provide better grip in the snow. Running a 19's instead of 20's is also better since you get more meat in the sidewall against potholes. That said, the width between the front and rear tires are only 10mm apart so it's not as big of a difference as some other models. A 20" wheel in the rear for winter is just asking for it IMO.
12-09-2022, 02:14 PM | #16 |
Car Geek
4255
Rep 3,902
I will probably go 255/40-19 all around for winter tyres on 19x9.5" wheels. The offset limits the wheel choice available, but I've been happy with the Braelin BR06 wheels we've used on our Macan S over the past 2 winters, so may order the same for the M2 as they have the correct centrebore and offsets available within 5mm of the optimum.
jordan24c129.00 Albator_IIII1062.00 |
12-09-2022, 02:26 PM | #17 | |
Rep 761
12-09-2022, 02:28 PM | #18 |
Rep 502
Very limited options available for the stock staggered setup if you want winter tires. Plus the 20-inch rears have very little sidewall that will surely not last a Colorado Winter/Spring in my case. 275/35/19 square setup is a good compromise, still pretty wide for dry grip/braking and multiple winter tire options available. Plus you can rotate the tires to get more out of the tread...
12-09-2022, 03:43 PM | #19 |
Rep 352
Drives: 2023 M2
You definitely want as much pot-hole resistance as possible with the winter set since you may not be able to see said potholes. I would try for 18's if at all possible. I busted a 19 on my Giulia and it didn't take much - and I mean busted. The rear 20's just aren't going to have hardly any sidewall to absorb impact.
12-09-2022, 03:47 PM | #20 | |
Rep 502
12-21-2022, 01:47 PM | #21 |
Rep 502
Shameless plug if you are already thinking about your winter setup like I do:
https://g80.bimmerpost.com/forums/sh...91&postcount=1
